I have fault code EP6on my sagemcom DTR94 and unit stuck and cannot access any menu
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Michael,
If you do not have your manual you can probably get it online at the manufacturer's website. Error codes are very specific. Most printers have a sequence of keys that you press in very precise order to reset the printer to default factory settings. This may be what you need. Don't throw it out yet!
A
Posted on Dec 03, 2016
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
Mar 05, 2018 | Taylor Ice Cream Makers
My coship CDBV2500E Recivier has 7U on the display and is stuck on one channel , is there a way to reset or default the unit given I can't access the menu either?
Questions, Troubleshooting Help & Support - Fixya
www.fixya.com/troubleshoot
My coship CDBV2500E Recivier has 7U on the display and is stuck on one channel , is there a way to reset or default the unit given I can't access the menu ...
How to remove this info off the screen? The info stays all the ...
www.fixya.com/.../t26024365-remove_info_off_screen_info_stays_all
14 hours ago - My coship CDBV2500E Recivier has 7U on the display and is stuck on one channel , is there a way to reset or default the unit given I can't ...
My kawai mr370 is stuck on the loudest volume and does
Dec 28, 2015 | Televison & Video
How to make my crystal 660 printer compatible with HP touchscreen?
Drivers are created by the manufacturer. This is made by the Swedish manufacturer, Sagemcom.
When I looked up the specs on the printer, I discovered that the manufacturer is Sagemcom. http://support.sagemcom.com/site/se/philips-fax-11/philips-crystal-660-337
Note that the top of the page tells you to go to a link for a critical update for the Crystal products. It will prompt you for numbers pertinent to your printer.
When you look at the bottom of that page, you discover the printer is XP SP2 compatible. There is no mention of it being Windows 7 or Windows 8 compatible.
Windows 7 driver.If you have Windows 7 Professional, Ultimate or Enterprise, you may be able to install your printer using Windows XP Mode.
You will have no luck searching for support on a Philips page but may through Sagemcom as advised above.
Feb 19, 2015 | HP TouchSmart Computers & Internet
Ac won't turn on after cleaning and E1 appears on control panel
E1, The e1 error code could mean multiple things. The most common fault with the unit is a stuck button on the access panel. Gently push each button in and out to ensure none of them are stuck. The panel may have malfunction due to moister. See that the unit is installed properly, and then leave it off for a few hours so the moister can dry up. if these two things dose not work then the temperature sensor could be bad. Heir 1-877-337-3639
Oct 01, 2014 | Haier 5200 BTU Window Air Conditioner...
Connect to sagemcom f@st 2864
1) reset the phone to the original manufactury default see your Menu AND do it 2) call to the supplier manufacturer Modem, and get the support via ONLINE chat for to fix it.
God bless you
Nov 24, 2013 | Polycom SoundPoint 330 IP Phone
Forgot parental code sagem dtr94
You will need to call the tech support center for the game console, if there is a way around the code they will be the only ones that can provide the information on how to do it.
Feb 06, 2012 | Video Game Consoles & Games
Need a master code to reset my dtr94 hd freesat tv reciever/recorder
From memory you need to get the channel list up then press green to unlock each channel in turn if any have been locked.
Aug 08, 2011 | Sagem PVR 6280 Freeview DTV Receiver /...
How do i activate my usb port on my sagem DTR94 HD Freesat
Can you please activate my usb port on my sagem DTR94 HD
May 12, 2010 | Televison & Video
k24674
jasbo
jasbo
