Question about Onkyo DTR7 Receiver
Will not turn on...
When I tried to turn on my DTR-7 this afternoon, I pressed the STANDBY/ON button, but nothing happened.  The red standby light is on (i.e., the receiver has power), but, other than that, it appears dead.
I'm very happy with the receiver and am interested in getting if fixed.
Thanks, Greg
Re: Will not turn on...
Same as above.
Unit or remote?
This is obviously a problem with this Onkyo Junk.
What do you want for $1000.00? Work too?
Posted on Oct 19, 2008
  • 45 Answers
Re: Will not turn on... - Onkyo DTR7 Receiver Audio & Video Receivers
Try unplugging overnite
Posted on Nov 20, 2007
0 characters
3 Points
What lights are on? What happens when you press the power button?
Apr 16, 2013 | Denon AVR-1909 Receiver
No sound from back channels of my dtr-7 stereo receiver
Do a Factory reset. it's most likely a speaker setting issue. press VCR and wille holding it press the Standby button. once you see clear on the screen it is done. try it now!
Nov 09, 2011 | Onkyo DTR7 Receiver
I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to...
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Dec 26, 2010 | Audio & Video Receivers
Today i went to turn on my receiver and the standby light is on, but wheni push the power button nothing happens.
Try to unplug the AC cable from the wall for a couple of minutes, in order to clear any trouble program. Then plug in AC cable again, with power button off, and press power on in receiver. Do not attempt to use remote for a while. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Audio & Video Receivers
None of the buttons on front panel works. I pressed each one but nothing is happening. I just got this through ebay.
Turn the power button on. It should light the switch. Turn it on from standby, it should light up the front panel. Then the switches should work.....unless one of the buttons got pushed in during shipping and it is still stuck in the pressed position. Check that all the switches push back when pressed.
Mar 18, 2010 | Harman Multimedia AVR-354 Receiver
Onkyo ht-r670 receiver is new and will not turn on. red standby light is on. but no display. also remote doesn't have any effect.
I would check any fuses first. The power transformer could also be open.There is a stanby supply that provides 5 volts that is always on . This is what supplys voltage for the standby light and the cpu. When you press the power button the cpu trips the power on relay that provides the 120v ac to the main transformer. If the transformer is open nothing happens. Onkyp part # is 2301798. Check the windings for continuity.
Dec 31, 2009 | Onkyo Audio & Video Receivers
Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Dec 25, 2008 | Sherwood R-945 Receiver
Onkyo DTR7 Receiver Logo
257 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
