Televison & Video Logo
A
Anonymous Posted on Dec 03, 2016
Samsung smart tv--by mistake pressed source button, now no cable signal
Bill Boyd
Level 3:
Top Expert:
  • Samsung Master 53,816 Answers
  • Posted on Dec 03, 2016
Bill Boyd
Samsung Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948743
Points
172802
Press source button again or select the correct AV channel
1helpful
2answers
Why is my Luxor smart tv displaying no signal when it is all connected
No signal from the box supplying the signal, or someone pressed the Source button on the remote and you are accessing an HDMI Port that has no plug in it.
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
How to repair a samsung Led tv model ua 50f 5500 amxxs. When I switch ON. it just show the flashing SMART Logo.It will not go to the tv channel.
If the TV displays the menu or Smart Hub when you press the button on the remote - the TV is on, it's just displaying a black screen. Change the Source on the TV to another input. See the page on Samsung TV has No Picture for more troubleshooting steps.
Depending on the TV, there will be a Jog Controller or TV Control Stick that will allow you to access the TV menu and change the source. Use the control on the TV to select an option - toggle it left or right to see if anything appears on the TV.
If the control menu appears on the screen, the TV is on but not displaying any input. Check the connections or change the input source on the TV. If the controller button works on the TV, but not the remote, check the batteries in the remote control.
Unplug the TV from the power source and leave it for a minute or two. Reconnect the power cable directly to the wall rather than a surge protector. If the TV Standby light appears - the TV is receiving power. If the Standby light still doesn't appear, please get in touch to organise a service.
1helpful
How do I get the signal on tv it used to work.my son pressed a couple of buttons and it hasn't worked since.i can't find my book for tv that come with it
seems like he may have pressed the source or input key on the remote however you can do this both ways to get things back in order by pressing the source or input key and the tv should turn back to the source you want (if however no signal still try going into the tv's menu and look for a dish icon (samsung tvs) and change it from air to cable or if cable to air) if the source isnt cable choose HDMI for your set top box (dish network direct TV or spectrum box)
1helpful
I hit the wrong button on the remote, and the tv now saids no signal. How do I get back to the channel the tv was on
hit the source button again that is for your scat press down to 1 HD should get you back on.
Why no picture, just snow?
Hey! We have a Samsung so it's prob not exactly like yours, but I thought it may be close enough. When our TV does this it's compliments of our 2.5 yr old.
........so on mine........
*Remote*
Hit [SOURCE]
choose - HDM1 satellite STB
*Side of the TV*
On mine you just press the side there's no "button"
It's SOURCE too. I just press it until the snow goes away.
Hope this some!! =)
1helpful
2answers
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
2answers
I pressed the source button by mistake, lost the picture with message 'No Signal'. I kept pressing it again when the picture came back but it is now fuzzy. Is there something else I need to do?
one thing you can do is reset the TV. You can go to menu, setting, then scroll down to the bottom and choose the reset all. The second thing is make sure that the source you have hooked up to the TV has good connection. Best way to test is to use a DVD player using HDMI or component cable.
Component cables produce "no signal" or "check signal cable"
I had exactly he same problem and it fixed by pressing several times the "source button"
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
