Question about Dyson Vacuums
I want to order Dyson Vaccum, I have my Sams card. Can you take my order now? Frances Myers
Our dyson vaccum is making a loud noise when we vaccum. (other than the normal loud noise) it is a dyson 23 plus..
Sorry to hear you're having trouble with your DC23 Plus. You might find it helpful to wash the pre-motor filter, and to check the cleaner for blockages. You can find a step-by-step guide showing how to do this in the Support section of our website:
http://www.dyson.com/support/help.asp?article=1276&product=DC23-PLUS
You should find that this resolves the issue. However, if you've tried this and you're still concerned about the noise, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON. We can run through some troubleshooting over the phone, and provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Jul 25, 2011 | Dyson Vacuums
How do i disassemble to get at the electrical cord and on/off button. I have a dyson dc21 stowaway.
Dear Sir/Madam,
When you have purchased the vaccum cleaner. how did you get the set.
Can you you tell by which manner did u purchased it.
But yes we can dismandle the vaccum Cleaner.by the manual which given to you when you have purchased.
Feb 25, 2011 | Dyson DC21 All Floors Stowaway HEPA...
The spinning brushes on the vaccum no longer spin, how can i fix this? The vaccum picked up a very small wire from a video game and i turned it off immediately. I unwound the wire but the brushes no...
You have either broken the belt or more likely the clutch easiest is to replace cleaner head assembly £75ish or call Dyson and arrange a service if you're not DIY inclined but check belt !st
Oct 31, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson Vaccum suction not strong enough
Look for an obstruction in the air passages at the bottom and where the air enters the canister. Make sure the HEPA filter is not plugged (take it out for a test). Hope this helps!
Mar 05, 2010 | Vacuums
It wont vaccum
If the brush isn't turning you need to replace the belts. You can get replacement belts here:
Dyson DC14 Belts
Nov 21, 2009 | Dyson DC14 All floors Bagless Upright...
The motor will not turn on. One minute it was
Called the phone number posted on the vaccum cleaner itself and my husband received technical support directly from Dyson. Problem solved at no cost to us. Vaccum is working fine.
Jun 03, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No vaccum at the hose attachment, the main powerhead has vaccum
You may have a blockage somewhere. Take the U-Bend (next to the right-hand wheel if you stand behind the vacuum cleaner) off. It is attached to the vacuum with a rectangular-shaped clip - it's purple. It is the pipe that is attached under the long gray hose. After that take out the AI Valve (the pipe above the right-hand side wheel) that has two purple buttons to remove it. Take the wand off and look through it - you should see light coming through the other end even though the wand is not straight all the way. If you can't see light through the other end the blockage is in the wand. Stretch the hose out and make sure there are no dark spots inside - those would be blockages. If all else fails call the Dyson helpline, they'll help you.
Apr 12, 2009 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Dyson animal
called dyson they told me to turn the vaccum on and off 5 times, lower the handle to the floor when it was off. Now try the vaccum again and it worked. This is somekind of reset.
Thanks Paul
Jan 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
37 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
