Mike Cullen Posted on Dec 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some computer keys not working
How do i fix
Marvin
Level 3:
Top Expert:
  • Office Equip... Master 85,242 Answers
  • Posted on Dec 02, 2016
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037466
Points
266281
You can't fix it you must replace the keyboard.
My Medion Erazor Notebook Enter key is not working?
What do I do if my enter key doesn't work?
Whatever the cause is, below you will find possible fixes that have helped many people resolve the Enter key not working problem.
  1. Restart your computer.
  2. Adjust your keyboard settings.
  3. Reinstall the keyboard driver.
  4. Update the keyboard driver.
Nov 29, 2021
How to Fix Enter Key Not Working [4 Quick Solutions] - Driver ...
Videos. You can also try removing the key and check for something jamming it, or clean the contacts under the silicone membrane.
https://www.google.com/search?q=Medion+Erazor+Notebook+Enter+key+is+not+working
How do you fix computer keys?
If you are talking about a separate keyboard just buy a new one....they are cheap. Some things are just not worth messing with and this is one of them.
F12 function key doesn t work
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard.
They are located at the top of most keyboards and labeled "F1" through "F12."
Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond.
Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up.
Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key.
This key is used to toggle function-key support; when it is toggled on, the function keys will not work.
Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software.
If the key does not work, press the "F-Lock" key a second time, and test the keys again.
If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality.
Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.)
Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7
http://support.microsoft.com/kb/975741
Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard
http://support.microsoft.com/kb/894513
Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database.
Agree to the terms and conditions, then download the hotfix.
When the download is finished, run the downloaded file and follow the on-screen instructions.
You may need to restart your computer after the installation is complete.
Your function keys should now work properly.
My fn button wont work
Some keys are not working on Starup (Random)
Your problem seems to be from the keyboard. Even if it looks good if the keyboard tape is out of whack or some key is no longer working, it can happen that you say, so I change the keyboard.
DiNovo Edge space bar and "n" key do not respond
I have the same problem with my dinovo after 2 years of usage, and i have found a temporary fix.
The temporary fix is to connect the dinovo to another computer and then hammer the keys vigorously, prefferably if dragging your finger over the keys, the keys will then start funcion immediately. Then connect dinovo to the first (main) computer again, and here the keys wont function, but after hammering them again vigorously it also starts working again here. However this is a temporary solution and the problem will probably reocurr. Notably hammering the keys on the first (main) computer wont yield any results even after long time of hammering without the second computer-lockup. Signalerror from logitech to specific computer? If there was dust this would never work on other computer so fast, and the error would not reocurr after being fixed.
Have product key need to activate
Try this Its free NEW VERSION and 100% working
Avanquest Fix It Utilities Professional 12 PLUS Keygen
http://adf.ly/FAkoo
The immoboliser light flashes when the key is turned?
this is how the immobiliser system works........you have a remote,it has 2 codes,one is fixed,one is random,the random code changes every time you lock the car,and this is the code the car reccognises to open/start the car.the fixed code is for simple key reccognition.the key has a magnet inbuilt that has a fixed code that matches the remotes fixed code.if you use a wrong key,the car will start,then die.the flashing light on the dash is a warning that the key code is weak and COULD cause a malfunction.use your spare keys and if the light still flashes you may need to have the keys recoded.(NO. YOU CANT DO THEM YOURSELF as the VW computer diagnostic computer has to match then reccognise the key to the car.) thats why when reseting the keys/car after a battery is changed you must go through the set/reset as shown in the handbook(that nobody seems to own).
2answers
On my daughter computer the keys for letters q w a s z x do not work - all the other keys work - any ideas
Aser 4720 laptop computer the keys for letters q w a s z x do not work - all the other keys work - i change new one but same problem any ideas
k24674
ADMIN Andrew
ADMIN Andrew
