Question about Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
The refrigerator temperature ins 50 and the freezer is 15. Is this the appropriate temperature? The butter is soft at this temperature
  • gmarx Jul 22, 2009
    I had a defrost recycle installed and the ckoils still ice up. they came and melted the build up but it continues to ice up. Do I need a new motherboard. The refrigerator is 7 years old.
  • Jenn-Air Master
  • 4,654 Answers
Appears to be skipping the defrost cycle. Locate the model number and I will be able to tell you were to look and how to fix. Thanks, Sea Breeze
Posted on Jul 20, 2009
  • John Tripp
    John Tripp Jul 22, 2009
    I don't believe you need a control board. There are usually three major parts to the defrost system. You changed one part. The defrost heater and defrost thermostat may be the problem all along. They are inside the back wall of the freezer and heat up during defrost. And the defrost thermostat turns it off when the freezer reaches about 50 degrees Fahrenheit. If you could locate your model number of Jenn-Air I could help you with part numbers. But if you would like to test these components yourself let me know and I will guide you with what you need to do. You will need an OHM meter and disconnect power for a few minutes. Thanks for the rate! Sea Breeze
    appliancepartsse@yahoo.com
2 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: the refrigerator temperature ins 50 and the
the fridge should not be above 40 degrees and the freezer not above 30. check back wall of freezer for frost. if so, coils are iced up and need to be defrosted. either take off back wall of freezer and melt ice with warm water or hair dryer, or unplug unit and let it set with doors open for a day. then clean up the water.
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
Ice cream does not seem to freeze it is always very soft. Everything else freezes O.K.
hi icecream generaly depends on the mixture & consistency need more clarity....
All fresh ice cream is somewhat soft, but should not be liquid. It will never be hard like it is in store. Let it churn until it is the consistency of soft ice cream, and then let it harden a bit in the freezer to get to the consistency you want. It's possible you actually let it churn too long and it started melting again.
Another method I used is to just put the ingrediants in the bowl, put in the freezer, and then take it out of the freezer and churn it myself, moving a butter knife around the edges to get all the frozen parts out, then a fork to mash it up. The ice cream takes less time to freeze and is generally harder
Aug 08, 2011 | Refrigerators
I woke up the other day to find my fridge warm and everything in the freezer defrosted. The light comes on when I open the door and what sounds like a compressor starts up every few minutes but seems to...
What you are hearing is most likely your compressor cycling on the overload due to drawing excessive amperage, You will have to have it checked out by a tech
Jun 26, 2011 | Refrigerators
I noticed a couple weeks ago the frig side was not cold enough. Milk spoiling but butter not getting soft. Freezer side seemed to be working ok. Now Ice cream in freezer is getting soft.
How old is the fridge? Most units have a system of tubing attached to metal fins, which is located in the back of the unit. This tubing & fins must be kept clean as dust will accumelate & insulate the freon gas from turning into a liquid.. Another problem is when the motor & compressor does NOT get enough air to cool the tubing & fins. This happens when the refrigerator is located in a closet type atmosphere where the unit is too big to get any air to the rear of the unit. NO spacing on the sides or top. ALSO, the compressor might of died. In this case, if the unit is out of warranty and/or over 7-15 years old, buy another, NOT worth the repair. If still under warranty, call vendor/manufacture.
Louie Almond
Mar 27, 2011 | Refrigerators
Refrigerator is not cooling.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 21, 2010 | Amana ABB2224D Bottom Freezer Refrigerator
Refrigerator very warm and won't cool , freezer working but...
if the compressor wsnt running it wouldnt get cold the real question is is there ice in the freezer on the back wall
Jun 02, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Jul 20, 2009 | Jenn-Air JCB2280HES Side by Side...
Freezer fine refrigerator is not as cold as it should be. dial is set to coldest position. butter is soft and milk is on verge of spoiling
do you notice ice built up on freezer section back wall if so you have a defrost problem if not you have a freon problem also make sure the freezer setting is not on its coldest setting this actually controls the air flow to the fridge section both freezer and fridge need to be set about half way
Jul 12, 2009 | Refrigerators
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
275 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
