Question about Ford Garden
1946 ford 2n tractor front mount distributor. Distributor sometimes turns, other times won't. What do I need to do? Bob
    Top Expert:
  • Ford Master
  • 80,339 Answers
Try replacing the drive gear on the the distributor shaft, it may damaged.
Posted on Dec 02, 2016
  • 2 more comments
  • Bob Ferguson
    Bob Ferguson Dec 02, 2016
    How do I get to the drive gear?
  • yadayada
    yadayada Dec 02, 2016
    You must remove the distributor from the engine.
  • Bob Ferguson
    I removed it and it fits into a shaft. How do I get to the end of the shaft?
  • yadayada
    I Have no idea, this was made 3 years before I was born. Sorry.
I installed a new front mount distributor on my 8N Ford tractor do I need to make any adjustments to timing?
Check timing because chance that you put it back in exactly the same location as before is remote and timing is critical to performance of engine.
Aug 31, 2017 | Ford Garden
Do not have spark on plugs
You need to check the spark plug wires. Check the continuity with an ohm meter if you have one. Rule of thumb is 10000 ohms resistance for every 12 inches of wire. Also make sure to check the coil as well. This should be located at the other end of the spark plug wires. Hope this helps and good luck.
Jan 19, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
NOT GETTING ANY FIRE TO PLUGS. TRIED TO CHECK THE
I just had to do the same. I removed grill and hood. Disconnect upper radiator hose. Remove radiator mounting bolt under left side (as you're looking at the front) and loosen the right mounting bolt. Radiator swings to the right to allow access to the distributor and coil. Lower radiator hose can stay connected as long as it will fold on itself without damaging. Remove the coil and distributor cap. Check to see that the rotor turns when cranking the engine over, to eliminate that potential firing problem. Then remove the whole distributor to replace points and condensor. It's a lot easier. Be sure to check gapping on all four lobes.
Jun 03, 2010 | Ford 8N Tractor
Garden Logo
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
