Question about Pool & Spa
Wirinmg diagram for SEARS12" tablesawMod#11324181 Serial# 7297Poo56
Saw motor says 240 V, orig wiring only has 3-wires 1 grd.,1black 1 white new cord end is 110 volt, motor growls , runs 1/2 speed (like 110 running 220) is there a 3-wire plug end for this saw ?
    Top Expert:
  • 77,932 Answers
Please contact Sears on this, we do not have these diagrams here.
Posted on Dec 02, 2016
Need 120 volt wiring diagram for model 113.299410 table saw with model 824370 motor
L1 L2 are the common or line,cord color doesn't mater, green is ground. also should be the ones with screws. try powering the motor for just a few second 2-3 at the most, if it snaps right to life you got it, if it starts slow or not at all, immediately shut it off and check the wiring again. pictures help us fixya guy help u better. there is thousands of different motors
Jun 03, 2017 | Pool & Spa
I have a 12 inch chraftsman table saw with 2 wires coming from motor. The wiring diagram inside the cap shows it to be wired for 240 how do I wire that thru a switch and to a three wire recepticle
Not quite sure what your question is - Are you trying to plug a 240 into a 110/120 outlet? Or are you trying to plug this into a 240 3 prong outlet?
Traditionally, table saws don't come with a power cord - you must supply one. Usually on the motor there is a metal plate that describes volts/amps/phase/hp etc. Get the Volts/Amps from this plate, then measure the approximate distance between your table saw and the 240 outlet. The gauge of the power cord depends upon the Volt/Amps and the length of the cord. There are many volts/amps vs length for wire gauge conversions on the net. I always get a bigger wire (smaller gauge) than what is recommended. Expect to pay $100 or more for the cord (don't be cheap here). If you have an under rated cord, you can start a fire, burn up your motor, melt plugs into outlets and have to replace the outlet (don't ask how I know).
I'm a little suspicious of the "white and black" wire from 240 - it's usually "white and red" with a "black" ground. 240 is made from two 120's - opposite sine wave. So black is usually the common ground, while the white and red are the two 120's. Volts between white-red=240, white-black=120, red-black=120. If you're absolutely sure that white-black=240, then you can just connect a ground wire to the motor case. Many home table saws can be wired for 240 or 120 - you need to make sure that you're hooking 240v to the correct wires. If you're uncertain at all, then don't do it.
I have wired 120 to a 240 motor by accident and the motor ran - it had no power and didn't spin at full RPM. You can damage a motor this way, so I wouldn't recommend it. I have never put 240 to a 120 motor - so I don't know what happens (guessing you could burn up the motor coils).
With all that being said, if you have 240 outlet with 3 wire receptacle, then just use a multi-meter to determine the 2 "hot" and the 1 ground. Volts from hot1-hot2=240, hot1-ground=120, hot2-ground=120. If you don't have a multi-meter, buy one (approx $12). Once you have it wired up, then try the motor by flipping the switch on then off again. If the motor didn't spin, then you did something wrong. If it hummed but didn't spin, you have some connections wrong inside of the motor. If it spins the wrong way, then your wiring inside of the motor is wrong (doesn't help to flip the wires on the outlet). If you blew a circuit breaker, then the wiring to the motor is wrong.
Sep 27, 2014 | Saws
Ge timer 15350 110 4 wires 4 post have 2 white on post 1 1 bk on post 2 0 wires on post 3 1 bk on post 4 2 grounds to the box pump will work manually timer will not work
Unknown if this is new installation, or existing install that stopped working.
Copy following link for wiring diagram showing GE 15350 timer:
Look at terminal labels, should be L 1 X and 2
Power coming from breaker should be 120Volt Black Hot wire, and White neutral wire.
Cable going to Load should be Black and White.
White wires should be on terminal X
Black Hot should connect to terminals L and 1
Black to Load should connect to terminal 2
If your timer looks different, repost question with link to photo on flickr
If timer stopped working:
GE15350 timer is 120 volt timer made by Tork.
It uses P47 trippers, and Tork 101 clock motor.
Jul 04, 2012 | Hardware & Accessories
2 speed switch wiring dieagram
The motor will have wiring diagram and voltage on nameplate.
You can re-post question with information that shows on nameplate for more exact information, or keep reading below:
If motor is rated for 240Volts, then it will not work with 120V.
If motor is rated for both 120V and 240V, then either Low voltage or high voltage will work, and one wire will be common, and 1 wire will for 120 and other wire for 240.
If motor is rated 120Volt two speed, then one wire will be neutral, and 1 wire low speed, and other wire high speed. You can connect your wire to either low of high, and cap other wire.
If motor is 240volt two speed, then one wire will be common, and 1 wire low speed, and other wire high speed.
If motor is rated 3-phase, then all three wires are connected to the voltage shown on nameplate.
If motor is rated 3-phase two speed, you may need electrician to wire the motor correctly.
Jun 08, 2012 | Westinghouse Electric Westinghouse...
I need help wiring in a new speed control on my bosch table saw 4000. The new speed control came with a large black wire, a small black wire and a small blue wire. The large black wire was easy and I...
ts4000 Bosch motor wiring (post #210578, reply #6 of 7)
by emils01 in reply to emils01 [original] on Tue, 09/30/2014 - 15:50
So I called Bosch on Monday and they were well informed and helpful. They emailed me a schematic and explanation of ...
4000 PCB wiring diagram.
1. White AC line cord to white field wire.
2. Black AC line cord to thin blue wire on PCB.
3. Black motor field wire to thin black wire on PCB.
4. Black long, thick wire on PCB to red motor brush wire with push on connector.
Sep 18, 2017 | Bosch 4000 - 07 Electric Table Saws
Low/High Switch wiring for Hayward Superpump
I do not read anywhere that you have a 230V DPDT switch which you will need in order to select the high or low speed. You will have 6 terminalas on the switch. Line connections usually go to the middle set. Put put sides of one pole to the common terminal and put one of the other posts to the hi and the other to the low terminal. I prefer to use am on-off-on switch so the switch in the middle turns off the pump. Flip it one way for hi and the other for low. If you post your stock number from the two-speed motor I could give you a more accurate diagram if you need it. Generally, 1 is common, 2 hi and 3/4 low.
Apr 26, 2010 | Pool & Spa
Replacing a worn out cord on my old black and decker worm drive saw. Where do the white black and green wires from the new cord go? The terminal on the switch only have a 1 and 2 printed on them.
Apr 25, 2009 | Saws
Pool & Spa Logo
177 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
