Question about Sony Televison & Video
Sony KV-32S45 Operator Manual - Sony Televison & Video
    Top Expert:
  • Sony Master
  • 8,211 Answers
Sony KV 32S45 Manuals ,try this link
Posted on Dec 02, 2016
How do you install closed captions
Press the Display button on the remote several times until Caption Vision appears. See page 16 of this manual for info about Caption Vision: http://www.docs.sony.com/release/KV32S40.pdf
See page 20+ for info about Setup menu and Caption vision menu.
Sep 16, 2009 | Sony KV-32S45 32" TV
KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Aug 25, 2009 | Sony KV-32S45 32" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Sony tv kv-32s45, standby light flashs continuously. diag code say "no reply from jungle IC301. Is this a board or circuit and where is it located? Is it on the power board?
The set needs service, count the no of times the RED LED blinks & contact the serv centre as it indicates the part problem.
Jun 12, 2009 | Sony KV-32S45 32" TV
TV does not power-up Red flashing light
andrews electronics.
(800) 289-0301 fax
800) 274-4666 phone
give them your model number and ask price qwote on replacment power suply.
the unit sounds repairable and the board is a simple swap.
daniel.
Jan 11, 2009 | Sony KV-32S45 32" TV
I have a Sony Trinitron Color TV that was manufactured in March 1999. The Model Number is: KV-32S45. The serial number is 8118319. My TV was accidentally plugged into a 220 outlet with an inadequate...
yes the power supply inside the unit is now gone.
it needs a rebuild.
or replacment, you can call a company named andrews electronics, give them your model number and ask them cost of power supply board..
hope this helps you.
Sony KV-32S45 32" TV no power
If the power plug is fused (like in UK) check the fuse inside the plug.
Test a different power socket.
If there is no power at all, and the power cord is good, then it is a faulty power suupply board. Probably a capacitor on power board had blown.
The board must be tested and repaired by a technician.
Jan 06, 2009 | Sony KV-32S45 32" TV
No power Up , No Sound , No picture
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
