Question about Garden
I have a 5hp briggs stratton engine when i took the housing unit off to replace the pull cord a wire came loose. The wire is coated black copper on end -engine will not start
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
The wire is for the kill switch one end goes to the cool the other to the kill switch if it is on off on the rewind there is a small hole in the bottom of the switch push up on the medal tang and slide the wire in
Posted on Dec 02, 2016
How much oil does a briggs & stratton 5HP engine need
Manuals You can download the manual for your particular engine from here.
Oct 22, 2016 | Briggs & Stratton Measuring Tools &...
Black small hose is loose on briggs&stratton 550ex mower engine
fuel should never be coming out of the air filter. do you mean the pipe that goes from the engine to the air filter housing? if so thats the crankcase breather pipe and you shouldnt be getting fuel there either. if you have fuel coming out of the air filter housing then you carb is probably flooding and will need stripping and the needle vale and foat looking at
Jun 21, 2014 | Briggs & Stratton Lawn Mower Air Filter...
Lawnmore pull cord replacement
Sears technicians can repair Briggs and Stratton cords fairly easily and it won't cost you much either. I had mine serviced last year and it took about 3 weeks and they just sent it off to the technicians and I just had to pay around $50 total.
Jul 07, 2012 | Briggs & Stratton Garden
Wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
Nov 30, 2009 | Air Tools & Compressors
I have a lawn mower that the pull cord that starts the mower brokeanyone out ther know how to fix? thanks ms. stiles
It depends upon what brand of engine you have on the mower but the most common one that seems to the most confusion with its owners is the Briggs & Stratton so here is the directions for them direct from the Briggs & Stratton web-site:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
If you are unsure how to do this, I suggest consulting a Briggs & Stratton Authorized Dealer located in your area. Your Briggs & Stratton Authorized Dealer has all the information relating to Briggs & Stratton warranty information, replacement engines, short blocks, parts, pricing, service/repair, specifications, etc.
Oct 23, 2009 | Craftsman Garden
Cord broken to start the motor
You neglected to specify but if this is for a Briggs & Stratton engine:
FOLLOW THESE INSTRUCTIONS FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you. You will have to remove the gas tank to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
  2. Remove the rope.
Oct 11, 2009 | Husqvarna Garden
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
