Question about Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver
I have a blackberry pearl and it keeps freezing on me. One of my coworkers said that I have to delete all of my data like text messages, etc for it to work but I want ot know if thats legit.
Cant read my sms messages on blackberry pearl
my blackberry pearl would delete my messages when i would get them. i took my phone in and they said to get a memmory card for it. i got one and know it works just fine
Jan 05, 2010 | RIM BlackBerry Pearl 8100
Sometimes my blackberry pearl won't send any text messages or call. I have to turn off my phone and turn it back on, but it'll only work for 5 min and happen again. Help?
It seems like memory issue.delete few messages or transfer all the data to media card.remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
Oct 17, 2009 | RIM BlackBerry Pearl 8100
Call logs lost every two months or so. Blackberry Pearl
its in your message options.... go to email.. or txt message.... go to Options...... General options... and scroll down to Actions... it will say keep messages.... it should say 2 months for you move it to forever.. so that it will only delete when you delete it
Jun 02, 2009 | RIM BlackBerry Pearl 8100
Lots of memory on blackberry pearl, but still deleting
Check to see how long your mail is configured for retention.
Open your in-basket. Press the menu button, and select "options".
Scroll to the bottom and the last option is "keep messages". You can set this for anywhere from 15 days to forever.
-Neil
Apr 23, 2009 | RIM BlackBerry Pearl 8100
Not recieving messages
Hi
1>There should be a red blinking light because you have a text message waiting
2>Deleate messages from your inbox cauz it is full
3>Next time you'll see it saving the messages
Feb 24, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl: memory issues?
I do apologize you are having this issue with the Blackberry pearl 8100. Lovely device.
The manufactur, RIM is aware of the memory issue. It's a known malfunction of the device. Luckily, there's a way to fix it, and keep your pictures, logs, address book, etc.. from deleting.
First, you should have a 1GB card for your photos.
Second your phone stores what it does. So, when ever you exit an application press the back button. NOT the hang up button. It'll only leave that application running in the back ground.
Third, you can clear history by holding on ALT+LG+LG. You'll get an event log. Press MENU key, and select "Clear history".
Next, clear the cashe. Open up Internet browser, press the menu key and select clear cashe. Once you have done that, press the back button to the begining. Save all pictures on the memory card. If you don't have memory card, connect your Blackberry to your PC and use the desk top manager to sync your media over via USB cord.
Now, that you are connected via USB cord and have the desk top manager up, run application loader. This should take a total of 20 minutes. Do not REMOVE from the cord. You'll ruin the OS on the Pearl.
Once all is cleared out, and updated. Do a check on your camera, your call log, and sms's. Periodically, delete your text messages. I would say, once or twice a month run the application loader. You can always check out www.t-mobile.com/bbupgrade for the latest and great software for you Blackberry. Or, go to www.blackberry.com/btsc for tips & tricks!
RIM always updates their software every 2-4 months. That way you'll keep your Blackberry longer and stronger! Enjoy!
Cheers!
Feb 03, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl automatically deleting messages
I actually had this problem a LOT in the past, it got so bad that I would get a message and it would INSTANTLY delete. Before I could even see who it was from, it would be gone. Then I looked for hours trying to find a solution, and found one. I haven't had the problem since, unless I have nearly a month's worth of texts in my phone. The problem is that your device memory is too full. If you have an SD card in your phone, I highly recommend moving any photos on your device memory over to the card. If not, then I HIGHLY recommend getting one, they are wonderful. If you do not have an SD card, and your budget is too small to get one, then delete any pictures on your device memory you dont need, or copy them over to your PC so you dont lose them, and try and keep your memory as empty as possible. Also if it happens a lot and bugs you, then every couple of days go in and empty out your message inbox also.
If this doesnt help then I dont know.
Jan 31, 2009 | RIM BlackBerry Pearl Smartphone
TRY THIS...Press and hold the up/down bottom left key. While holding this down press L then 5 then L then 5 again. an event log will appear now press the menu key scroll down to CLEAR LOG. USING THE TRACK BALL PRESS THE BALL AND DELETE THE EVENT LOG. These are cookies and will destroy your memory which is very small anyway. Do this from time to time and it should solve your problem. Good luck to all......
Mar 03, 2008 | RIM BlackBerry Pearl 8100
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
102 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
