Question about Vacuums
I started vacuuming and the vacuum motor slowed down, then stopped. I smelled a burning smell. Then I discovered the next day that the bag bottom was wet and falling apart. Sebo X4 model
Apparently I vacuumed liquid. I want to know what is likely to have happened when I did that would cause the vac to shut down and smell. What was burning. What would it take to repair.
    Top Expert:
  • Vacuums Master
  • 51,277 Answers
Sucked up liquid goes with the air through the motor
that would cause the motor to burn out
with the current low cost of new vacuums , the repair /replacement of the motor would be close to a new unit
take it to an appliance repair shop and get a proper diagnosis and quote
Posted on Dec 02, 2016
Testimonial: "Thanks. I will get that quote. (New Sebo is $800)"
  • Bon B
    Bon B Dec 02, 2016
    Thanks - exactly what I wanted to know.
  • Vacuums Master
  • 20,966 Answers
That is an antiquated vacuum and is way overpriced. Get a Dyson, no bags, and no loss of suction!
Best Vacuum Cleaner SEBO AUTOMATIC World Best Vacuum Cleaner
Testimonial: "Have used Dyson a lot. Does not clean carpet as well. But thanks."
GREEN LIGHT AND MOTOR
The green light is an indicator that your brush is rolling smoothly. If it starts to flicker and you smell something that smells like rubber burning you need to do a couple things; one is remove the roller and clean off all of the hair, string, etc. Next you want to replace your belt. Just because the roller isn't turning doesn't mean the motor and the belt aren't either. If your roller gets jammed your belt will continue to spin and it will eventually wear down in one spot and break. Replace the belt, clean the roller and your should be fine.
Apr 26, 2013 | Kirby Ultimate G Bagged Upright Vacuum
A smell like burning rubber comes out of the vents whenever it is used. It starts as soon as the vacuum is turned on. I've emptied the filter, but maybe I need a new one? I don't think the suction...
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Please take time to rate me
Aug 30, 2011 | Dirt Devil M083405 Versa Power Stick Vac...
My dtx1300 burned out when my son kept vacuuming with the bag full suddenly it stop working and I could smell a light burn.what part would do that so I could may be fix it?
the belt that drives the beater bar may have broken. If you noticed a burned rubber smell it was the belt and you can find the part number in your book that came with your machine.
Aug 16, 2011 | Oreck DutchTech DTX1300C with Motorized...
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
Oreck XL intellashield smells hot and smoky when operating. New bag and belt and no clogs. About a year old.
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Dec 17, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
May 25, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover S3639 Windtunnel Vacuum not on after burning smell
how old is it ?maybe the motor went south.take the cover off and see if you see any burn marks ,maybe you can narrow down the burnig smell.i don't charge people for helping i just enjoy helping.314-628-9153
Apr 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Burned smell
If the motor slowed down this would indicate a bad motor. not cost effective on this model to replace unless under warranty. it is not uncommon these days to see a motor go bad every now and then.
What are the first 4 digits of your serial number? this would be the month and year of mfr. even without a receipt, a warranty service shop should be able to assist you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 21, 2008 | Hoover U5507900 Elite Rewind Bagless...
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
57 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
