Question about Lexmark X4270 All-In-One InkJet Printer
Error #1200 appears on screen
Printer will not print because it states that it is "busy," and posts this error on the screen. Please help.
    Master:
    Sergeant:
  • 226 Answers
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
Posted on Jul 20, 2009
What is the meaning of the Red & Blue flashing lights on the printer?
Now your printer in Service Mode.
It's time to reset the printer.
Apr 09, 2016 | Ricoh Aficio SP 100 e Laser Printer -...
Error 1200
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Feb 08, 2012 | Lexmark X Office Equipment & Supplies
C1e codes comes up on screen and it will not print.
EC1 error indicates a problem with one of your cartridges. Please follow the steps below to fix the problem:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
5. Unplug and re-plug the printer into the power source to reset it.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X2670 All-In-One Printer
The printer just finished printing 7 pages and it clicked and the showed 122.05 Service fuser error.
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $300 for a new one, so I think you would be better off getting a new printer unless you find a second hand fuser on Ebay. They usually send for under $100.
Jan 25, 2011 | Lexmark C543dn 26B0000 Workgroup Up to 21...
My notebook detect hp business inkjet 100 but i can't print files. need your assistant thank you -khandy-
have you installed the printer drivers ...... please install the driver first ...... post the comment if you are getting any error ....... if you installed the driver and still its not working please open the printer and faxes from the control panel and check your printer driver status ..it should be ready ....... please post your comment if you are getting any error ....so we can help you correctly ....
Jan 08, 2010 | HP Business Inkjet 1000 - Printer - colour...
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
ERROR 1200
This error is caused by the cartridge carrier stall. To troubleshoot this problem, please visit the below mentioned link:
Troubleshoot - Error 1200
Please rate it Fixya if helpful.
Thank you
Feb 18, 2009 | Lexmark X4270 All-In-One InkJet Printer
The printer has an error stating ERROR 1200
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
Jan 30, 2009 | Lexmark X4270 All-In-One InkJet Printer
Trouble with HP Business InkJet 1000
ur check all the sensor one bye one indivisual in dislpay scareen error code are different .mpost probablity this error front cover.
Jan 19, 2009 | HP Business Inkjet 1000 - Printer - colour...
Lexmark X4270 All-In-One InkJet Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
