Question about Elna Sewing Machines
The thread take up guide on my elna 820 is jammed It worked when it stoped for colour change did not return to the top I have tried to turn the hand wheel but it will only move a fraction ether way
    Top Expert:
  • Elna Master
  • 8,204 Answers
DIY Fix Broken Sewing Machine .not sure if this will help you out
Posted on Dec 02, 2016
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
Elna expressive 900 thread breaking (although not really) and bunching up on underside of fabric ESPECIALLY when doing embroidery. Why?
try using gutermann thread and needle according to your fabric thickness and tension dial must be 3-5 and bobbin thread hold the end of the thread and bounce to see how loose the thread is cos if it releases too easy you need to turn the screw on the casing just a little see how you go
Apr 08, 2017 | Elna Sewing Machines
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
My elna 2800 is jamming the bobbin the thread keeps wrapping around the bobbin case. What can I do
try changing the needle, make sure the machine is threaded correctly,using every thread guide. make sure the top thread hasn't come off the thread take up lever, try a different bobbin, could also be a timing problem
Dec 03, 2014 | Elna Sewing Machines
How to adjust the tension on Elna 614de
try rethreading the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
& that the bobbin is turned the correct way
Aug 25, 2012 | Elna Sewing Machines
Bernina 820 Tension Error Message
You need to take your machine in for service. The 8 series machines have new upper tension parts that can be installed under manufacturer warranty and MAKE SURE your Bernina dealer is well trained on the 820 and 830 or they'll never get it adjusted right. The 8 series are just all around buggars when they're out of whack.
May 20, 2012 | Bernina Sewing Machines
Elna 9000 bobbin problem
try changing the needle,,make sure the needle & thread & fabric are correct for each other
make sure the bobbin is turned the right way
it's also possible that when the needle gets jammed or broken that the machine can become out of time
and would have to be retimed at a sewing machine shop
Apr 01, 2012 | Elna Sewing Machines
Elna Supermatic 1960's/cream and blue. The machine is jammed. Hand wheel will turn backwards but not forward. I pulled some quilting thread out out the bobbin area, but didn't fix problem. ...
There may be threads jammed up in the bobbin holder area causing the jam. But removing the inner bobbin holder is a bit tricky if you haven't done it before. There are two little screws holding the silver inner down onto a black ceramic piece (inner guard ring), and you need to get these lined up the right way to get the bobbin holder back into position afterwards.
I would suggest that you join the Yahoo group Elna Heirlooms, then check out the files and photos loaded up by other members who work on their Elnas.
You shouldn't need to remove the feed dogs, just give them a clean with a little brush. But internally the machine may need a good clean and lube and without a service manual or good guide this can be challenging.
If you go this link you can down load the manual for this machine, the Star Series SU. Go to page 7 of the first part to see about removing the bobbin holder and inner guard ring.
It is a case of lining up the cut out of the black plate to the front, then putting the bobbin holder on top with the little arms facing front also, then replacing the two screws.
I'd suggest you take photos with a digital camera before you start to help you get it back in the right way.
I hope this helps you with the Supermatic, did you get the discs and accessories with it too? lovely Swiss quality machine with great stitching so if you can't get it unjammed, you may wish to find an experienced Elna Technician to take a look.
White Sewing Center stock lots of parts for these machines too,
Jun 08, 2011 | Elna 1010
Sewing Machines Logo
32 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
