Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Connecting brother intellifax770 fax to my window xp
Ilost my manual and need help connecting to my comouter i need this as soon as possible
Well, don't hold your breath, because it's not a printer.
Posted on Jul 20, 2009
Brother Intellifax 770 - how to connect to PC?
The intellifax-770 deffinetly cannot connect to a PC. There are several other models that can, but not this one.
May 29, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
I want know how to connect it to the PC
You can connect it to your PC with a USB cable, and you'll need to install Brother's printer driver to run it. You can download the driver at http://solutions.brother.com According to the manual it will run on operating systems up through XP. There's is no data on Vista or Windows 7, but an email to Brother customer service should answer that question. Need the manual? You can download/print it at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
Dec 29, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Fax problems
I think you just not plugged with the phone/fax cord.
Please check the cord is connect or not.
Mar 16, 2009 | Brother MFC-7340 All-In-One Laser Printer
Intel Fax 2820 Back cover open
There is a problem with that machines exit sensor not swinging properly. Open the back cover and look for a sensor in the middle. Try to swing it gently to loosen it up. Close the cover and try it again. If no help, then you will need to check. brother-usa.com.
Jun 14, 2008 | Brother Office Equipment & Supplies
Brother intellifax 4100
open front cover, press "clear" and 1, that will clear the change drum soon error
Jan 14, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
