Question about Honda EU3000iS Inverter Generator
Honda 3000is intermittent no start, and sometimes stops while running. Sometimes backfires while trying to start. . Spark only on first few revolutions then no spark, when tested with plug out
Does this unit have a coil? Where?, Magneto..
emissionwiz
  • 78257 Answers
SOURCE: honda accord 1996 v6 2.7 liter,rpm gage jump up and down
Here is the most common cause of surges and stalls, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Posted on Nov 28, 2008
daves944
  • 1050 Answers
SOURCE: 1991 honda accord "no spark"
There is a relay mounted way up under the dash on the driver side. It is about 1"x1"x2" and it says Mitsuba on it. This is the PGMFI relay, sometimes called the main relay or fuel injection relay. It is very likely the problem. You can buy another one, or there was a bulletin on how to repair it. You need to take it out, pop the cover off, and resolder the cracked solder joints on the pc board that the relays are mounted on. Really not that hard if you have a little soldering experience. If not, just buy another one, about 50 bucks.cb28323.jpg
Posted on Mar 26, 2009
SOURCE: bike wont start. everything works. no spark on plugs
98 honda shadow ace wont start electric switch is sticking and the headlight doesnt come on when key is turned on
Posted on Apr 04, 2010
  • 18 Answers
SOURCE: 11 hp honda pressure washer
if you replaced the coil,check the wire and boot,check with meter for continuity.could be loose connection to spark plug
Posted on Sep 20, 2010
LandaNW
  • 45 Answers
SOURCE: honda 13 hp will not start, will run on starting
If this machine has been sitting for an extended period of time it is likely that you have a couple of things going on. First you should drain the fuel from the gas tank. Next remove the bowl from the carb and using a flat head screwdriver remove the mainjet from the carb. Check that it is clear then re-assemble. Next pull your spark plug. Put a rag over the hole in the head where the plug was and pull the engine over a few times. Re-install the plug. Now remove the grey oil dipstick from the engine and check for the oil level being over full. If it is drain the excess.
Doing all of this should solve your issue. In most cases the problem you describe is caused by varnished / rotten fuel, a faulty carb float allowing fuel to drain into the crankcase creating excess pressure or water buildup in the cylinder creating excess pressure.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Posted on Feb 13, 2011
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Missing and backfiring in 1987 honda civic
Check the following items:
- Check the spark plug gaps. (0.90 - 1.0 mm)
- Check the resistance of spark plug high tension cords (10 K Ohms - 25 K Ohms)
- Check the distributor cap and rotor for cracks and or corrosion.
- Check ignition timing (17 degrees at 750 rpm)
Apr 07, 2013 | 1987 Honda Civic
I have a husqvarna 261 chainsaw. it will start half the time....the other half...no chance.i changed the spark plug.and im getting very good spark. took the carb apart and cleaned it. checked the plug when...
Hi, from what you have written I believe you have a faulty cdi unit. Carbys don't generally run perfectly intermittently. To test the cdi theory, close the sparkplug gap to approximately half normal gap. If the saw runs fine you have a faulty cdi, shorting ht lead or stop wire. Regards Phil.
Apr 26, 2011 | Husqvarna Garden
Backfiring through rear cyclinder. Cleaned carb, replaced exhaust gaskets, valves did not need adjusting after 45000 miles. Bike runs great just backfires sometimes
Check the wiring to the spark plugs and replace if necessary.If that does not solve then go one step further backwards towards cdi etc...
Nov 05, 2009 | 2005 Honda VTX 1300 C
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
02 with 44k miles. Stalls intermittently and backfires at start.
Fuel filter.or catalitic converter. I had 44000 on my Monte Carlo when it acted like it could not breath. The catalitic converter was clogged. I got a new high flow type.GM covered my replacement.
Sep 02, 2009 | Buick LeSabre Cars & Trucks
300 Bayou stops running - sometimes fails to start
check the carbs float height if to high will keep blowing spark plugs also do the fuel/air mixture screw it will say in the manual e.g 2 1/2 turns out this means screw this screw right in and unscrew the correct amount off turns also make sure your running the correct plug as i have used too cold plugs and have kept blowing try a hotter plugeg br8es <cold br9es<hotter good luck bud
Jul 13, 2009 | 2000 kawasaki KLX 300
1999 Corolla Cutting out and backfiring
misfires can be lean/rich conditions at 1 cylinder only ..or spark or mechanical issue...sooo....compression/leakdown test to determine health of mechanical rotating parts ...valves pistons timing......timing belt......vacuum leak at intake manifold affecting mostly one cylinder...or no/intermittent spark to one area...coil/igintor wire plug ..read plugs... the misfiring cylinder will be different looking
Oct 15, 2008 | 1998 Toyota Corolla
Open Questions:
See all Honda EU3000iS Inverter Generator Questions
Honda EU3000iS Inverter Generator Logo
131 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
Richard Warren
Richard Warren
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
