Question about HP Cameras
Equipment; HP Envy 700-327c Ser. #mxx4200rqz Model 3F07AA Running Windows 10 upgrade. Monitor-Envision G19LWK. Problem= Blurry, shadows on Right side of all screen items. Comes and Goes.
Can I send you a screen shot of problem when it happens? Thank you, RustyBore
  • 1694 Answers
SOURCE: Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Posted on Dec 04, 2007
C13295
  • 128 Answers
SOURCE: Blurry on left side of the screen. Shadowing in different colors.
Try this website. It is the Hitachi support website. http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support Hope this helps :)
Posted on Jan 28, 2008
easyab
  • 132 Answers
SOURCE: three inch shadow running down on right side of screen
Light Tunnel needs replacement.
Web page describes:
http://calgaryconvergencerepair.weebly.com/samsung-light-tunnel.html
If you are in Calgary, Alberta, email me.
If not, look at the repair person finder at Homepage of the Fixya site.
This is only for the Samsung DLP, comment is not indended for the other makes listed below the problem.
easyab
Posted on Jun 27, 2008
SOURCE: trouble with sony cyber-shot DSC-T33
try cleaning the lens first.
when taking the picture press down lightly so it will focus. Then press harder for the picture.
Posted on Aug 10, 2008
darntoothysa
  • 489 Answers
SOURCE: Digital Camera
Hi
E:61 is a Sony error code for a problem with your lens.
Initializing the camera will put all the settings back to default which can sometimes fix a camera that will not power up or does not function properly in other ways. I love Sony models that have the "Reset" button either inside the battery compartment or on the bottom of the camera, I don't have a T70 on hand to tell you if you have a reset button or not, but if memory serves I do not think you do.
If 'Initializing' the camera does not work then the next step would be to try replacing the lens. If it's still under warranty try sending it in for service. If its not, either look for a parts camera on eBay, or let me know, I know where to get new OEM lenses for amazing prices.
Good luck from Darntoothysam com
Thomas
Posted on Sep 26, 2008
Resolution notice
Your monitor is not running in its native resolution, so there is notification to change your display resolution, then you have to check driver for your video card. Upgrade the driver fot your video card. Where will be the setting to change to 1440 x 900.
Nov 08, 2013 | Envision G19LWK Monitor
How do I turn the sound on
There will either be a menu driven volume control or physical volume buttons. Also make sure you have an audio cable plugged in from the monitor to the computer. It will typically be a lime green port on both. Connected by a 3.5mm head phone jack
Feb 02, 2013 | Envision G19LWK Monitor
Control screen wont go away
You mean the one that comes on when you hit the "configuration menu" button on the monitor? Typically hitting that button a second time makes the menu go away.
Dec 01, 2012 | Envision G19LWK Monitor
My G19LWK has been fine for 5 yrs then the other day I restarted my computer and the screen just went white.
Hi, This is may be your monitor problem or your system problem. It may happen for moisture. Check the OS login sound to make sure that there is no problem with your system. If you got the proper sound then the monitor is bad. First adjust the monitor brightness and resolution or press auto adjust button. Reboot the system and try to login in BIOS to make sure about system problem. If there is any problem in system then first clear the ram and reinstall it. Check the power supply also. Try to login in safe mode and set the display in lower resolution. Then again reboot the system and login normally and reset proper resolution. If it doesn't your problem the you have to repair the PCB of the monitor.
Sep 15, 2011 | Envision G19LWK Monitor
Yellow line down middle.
solution is only can replace lcd screen
Jan 18, 2011 | Envision G19LWK Monitor
"Out of Range" message appears and the icons are blurry.
Out of range means that you selected the resolution that your monitor does not support.
Your monitor works on 1440 x 900 / 75 Hz.
right click on blank space on desktop and select screen resolution. Put it on 1440x900.
Jun 19, 2010 | Envision G19LWK Monitor
Out of Range message in middle of screen. Cannot get rid of it. Monitor Menu not working.
You might set the resolution to higher which your monitor doesn't support. Well do follow this, remove the cable and reconnect, reboot your PC. It's also important to let me know the operating system, (sometimes pirated XP Service Pack3 creates this problem). Good luck..
May 15, 2010 | Envision G19LWK Monitor
Remove base of envision lcd monitor G19LWk
The base of the G19LWK can be removed but it takes a little work. You have to remove the black plastic case that sandwich the LCD screen. First remove all the screws on the backside of the monitor. Then, at the seam of the two casement halves, GENTLY pry the front screen frame away from the display. Work carefully all around the edge of the display to separate it a little at a time and the pull it away in one piece. Next you will find that the back casement is held to the display with plastic tabs around the perimeter. Carefully pry the tabs away from the display frame to separate and remove the back casement. Now the base mounting is exposed on the backside and held with 4 screws. Remove the screws and the base will come free. Re-assemble the casement by snapping the back on first followed by re-installing the screws. Then snap the front frame by lining of the plastic tabs and pressing the frame down evenly around the display. You are done!
Jan 30, 2009 | Envision G19LWK Monitor
ENVISION EN-985E MONITOR PROBLEM
When using this monitor on a PC running Windows Vista Home Premium the screen text is blurry and hard to read . I have tried working with the Clear Type in Vista and that does not help . I have reloaded the driver for this monitor and this did not help either . Any suggestions ?
Steve
Dec 05, 2007 | Envision EN-985e Monitor
Cameras Logo
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
