Lid is open and not close how it will be close and remove this option
    Top Expert:
  • Computers & ... Master
  • 8,204 Answers
More info please,the lid on what?
Posted on Dec 02, 2016
2 Suggested Answers
  • 11 Answers
SOURCE: no more option on advanced power to standby when lid closes
all you need to do is,Boot your computer nomally then click on start then run,type msconfig-then click system restore.on this restore your computer to earlier dates before it started mis behaving.Give us feed back.
Posted on Aug 04, 2009
I closed the lid without shutting down & now it won't turn on
just whether only the screen lights are off(dim) or actually laptop is shut down.. otherwise remove the battery and then start the computer and after opening search for lid and close and then setting will open and then change "what happens when u close the lid" or make it to do nothing "Change what closing the lid does" - exact search words
Sep 05, 2015 | Computers & Internet
When I open the notebook the power comes on then shuts off. when I open the note book all the way up it stays on
Click "Start."
Click "Control Panel."
Click "Power Options."
Click the "Change What Closing the Lid Does" hyperlink on the left side of the screen.
Click the "Closing the Lid" drop-down menu. Select either "Sleep," "Hibernate" or "Do Nothing." All three of these options will stop your Acer laptop from shutting down completely when you close the lid. Click "OK" to save changes.
Oct 11, 2013 | Acer Aspire S7-391-9886
Dell insprion laptop is still running after closing the lid
open control panel and go to power options. you should see "choose what to do when you shut the lid" click it and choose.
Nov 26, 2012 | Dell Inspiron 1501 Laptop
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
Everytime I lock my computer,shut the lid or leave it untill it goes black, it will not come back on when I touch the mouse pad. However when I got this laptop it worked and when I opened the lid and...
Well by default Closing the Lid will cause computer to go to Sleep mode and you can't wake it up using mouse. However you need to press power button to wake it up.
But as you said it was working the way you explained then seems like Power settings on your computer are changed
To check the settings Got0 -Control panel and click on power Options Goto - Advanced and find the Lid open/close actions You can change it there If you don't want your computer to goto sleep mode with the lid close, you can simply disable it.
Hope this worrks
Jul 14, 2011 | Computers & Internet
I need to replace the lid switch in my gateway 7510 GX or else simply disable it. I removed the button that gets pressed but seems the circuit is already messed up, and I need to mess with it every time I...
Try this, go to Control Panel, open "Power Options" and on the left pane, click "when I close the lid...." or similar options for Lid and and choose "Do nothing" on both the options available on "Close Lid" menu. Save the settings and try whether this helps or not.
(you can go to the power options by right-clicking the desktop, select "Properties" then to "Screen Save" [XP] or to "Power" tab.)
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | Gateway 7510GX Notebook
Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Oct 01, 2009 | Dell Inspiron 1300 Notebook
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
White screen if i close lid and open it
disable hibernation and disable the option make it "do nothing when i close my screen lid"
Mar 10, 2009 | Acer Extensa 4620 Notebook
Goes into standby when I OPEN lid
ok - if you are using XP -go to your start menu - control panel
click on power options and click on the 'advanced' tab - this will give you the options of what happens when you shut your lid.
if using Vista - click on control panel, choose 'classic view' from the left sidebar and carry on as above
hope this helps 8)
Dec 07, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
