Question about Building Materials
How do I change out a receiver on a garage door opener
Doorguy27
  • 30 Answers
SOURCE: Need to change the freqency on a lift master garage door
Chance are they set there remote when you were using yours. To reset your opener you need to clear all the codes on the back of your opener itself there is a square button purple or red depends on how old it is. Press and hold that button until the LCD light turns off. Press your remote to make sure it has stopped working. Then press the button again only for a sec until the light comes on and starts to flash then press your remote button. Repeat for each remote.
Posted on Feb 10, 2009
katsov
  • 10 Answers
SOURCE: my garage door opener only works from inside the garage
try repositioning the antenna that comes off of the opener. make sure there are no obstructions around it
Posted on May 22, 2009
  • 3197 Answers
SOURCE: I've got a Sears/Craftsman 1/2 HP garage door
If you have the wall control with 3 buttons one of them is the lock button. It is not on the side. If you have it and the light in the wall control is flashing, press and hold the button with the lock icon for 3 seconds and release. If that is not the situation your receiver is bad. The receiver is inside the motor unit and is part of the logic board.
Posted on Dec 30, 2009
  • 3197 Answers
SOURCE: keypad won't program to garage
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
Posted on Oct 03, 2010
  • 3197 Answers
SOURCE: I need the receiver and
I think you will need to check into a Sears Model #00953751000 or Chamberlain Model #R39663 universal remote control replacement kit.
Posted on Apr 14, 2011
I have an ET 500 gate motor. My neighbour's remote opens my gate as well when she opens her garage door. How can I change my ET receiver to prevent the neighbour opening my ET gate motor?
Most garage door openers and I assume gate actuators have jumpers or settings if computerized to change frequencies.
Both the remote and unit will have to be changed.
Larry
Aug 05, 2016 | Building Materials
What is the different between 41AB150-2 and 41AC150-2?
This receiver logic board (part number 41AB150-2) is for garage door openers, including Craftsman garage door opener model 13953904D.
This receiver logic board (part number 41AC150-2) is for garage door openers, including Craftsman garage door opener model 13953901DM.
315MHz Security Radio Controls Purple Learn Button Replacement Garage door opener receiver logic board 41AB150 2 for... 25313039-z4aba1t3xnu0kgnrds04j5va-2-0.jpg
Dec 08, 2014 | Cars & Trucks
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
My garage door opens when the neighbor opens his garage door
somehow his controller has "grabbed" your frequency which you already know, you cant change the frequency of you garage door receiver. what you do is unplug you opener and have him reprogram his remote to his door while your receiver is incapable of being programmed. somehow your receiver was in program mode when he set his door opener up. at the back of your opener there should be a red button that allows you to program new receivers, make sure this isnt damaged or stuck while pushed in. i have tried these ideas with some success.if this doesnt work then try reprogramming both yours and his from scratch, one at a time while the one not being done is unplugged. hope this helps
steve
Nov 07, 2013 | Overhead Door 109130-390 390 MHz...
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
My remotes will not activate the garage door opener from anywhere but inside the garage. Worked fine the first month then stopped
Have you tried changing the batteries in the remotes? The other explanation is that the antenna in the receiver in the garage needs re-siting or extending.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have Genie Screw Drive garage opener...the problem is the remote is not opening the door...the wall unit will open.... changed the battery...not working...the unit is about 10 years
If you have only one remote it is impossible to determine if it is that or the receiver that is bad. The wall unit doesn't use the receiver so that doesn't tell you anything. No good answer.
Nov 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
I've got a Sears/Craftsman 1/2 HP garage door opener. It's older, it was in the house when I bought it 11 years ago -- model #139.53600 The door will open when I press the pushbutton inside the garage,...
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Keyless entry doesn't work
The remotes and keypad use the receiver which is part of the logic board.'t The button on the wall is hardwired and doesn't use the receiver. You might pull the logic board and check for bad connections on the printed circuit.
Nov 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening by itself
Most likely you are receiving an outside wireless signal that is activating your garage door. A neighbor nearby could have an opener that matches your wireless frequency. I live near a military base where years ago the base installed some wireless equipment that caused my door to automatically open. My suggestion would be to change the frequency code. Open up your wireless remote button. On most openers there will be a number of small rocker switches which are marked ON & OFF. Using a pen set these switches to a different configuration and then do the same at the wireless receiver which is located next to the overhead garage door motor. Be sure the opener and receiver's switches are set to the same configuration. This should take care of your problem.
Aug 07, 2009 | Universal Garage Wireless Keyless Entry...
Building Materials Logo
82 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
