Convectair 7359-c05 error code AU 7 - Office Equipment & Supplies
4 Suggested Answers
SOURCE: Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem.  It will also come up if your power cord is loose.  You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on.  It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
Posted on Oct 15, 2007
SOURCE: Forgot to reconnect heater when
PROBLEM SOLVED
MINOLTA EP 1085 COPIER, RESET BUTTON ON MAIN BOARD.
THANK YOU
Posted on Aug 21, 2008
  • 1297 Answers
SOURCE: minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
Posted on May 22, 2010
Minolta EP 2030 error code C05 how to reset
open the front door with power on in the upper left you should see a small panel remove the cover, press the small switch wait for ready to copy, if the code comes back do not reset the FUSER is bad it can start a FIRE ruining a perfectly good day!!!!!
May 10, 2017 | Minolta Office Equipment & Supplies
C05 60 code error, minolta dialta di183
Scanner home sensor clean with can air or replace
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta cspro 2010 error code c05
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
MY KONICA 7115 COPIER HAD DISPLAYED ERROR C05 00 CAN YOU HELP ME
turn off the machine and hold down the STOP botton while turning on the power .hold for 5 seconds .
than should reset the code .if the code pressist that you have a bad thermester in the fusing unit.
good luck
May 01, 2010 | Xerox CopyCentre C118 Copier
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
the error in the fixing unit
try to clean the upper roll thermostat
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
Oct 13, 2007 | Office Equipment & Supplies
27 people viewed this question
k24674
jasbo
jasbo
