Question about Westinghouse Washing Machines
Model LT809S Westinghouse how do you unblock the pump
5 Suggested Answers
  • 29 Answers
SOURCE: My westinghouse lt809s is very noisy while
Then you probably either need to clean that bearing assembly up or go to an appliance parts center and take the model number with you and purchase a new bearing and pulley assembley.. Also check for worn belt.
Posted on Mar 12, 2010
Testimonial: "Thanks. I think your suggestion is spot-on!"
SOURCE: My westinghouse washing machine LT809s
It means Low Level. Your water level is too low. Your machine isnt filling up properly or the water is being siphoned out as it fills which means your drain is lower than your water level. or your drain does not have an air lock in it any more.
Posted on Jul 27, 2011
SOURCE: My washing machine westinghouse LT809s
We moved our machine going perfectly fine untill then. Now displays a HC sign eater will fill in machine on any cycle then empty out at the same time so doesn't fill at all. Help please
Posted on Jan 03, 2012
  • 42026 Answers
SOURCE: WHAT is causing my Westinghouse Top Loader Washing Machine model LT809S to only agitate in one direction ??
problem with the direction control relay or power board
call a technician to diagnose properly
Posted on Jul 21, 2015
Testimonial: "This model does not have a direction control relay nor a reversing module as was suggested by someone else. The reverse agitation is controlled by the mother board. I was advised to upend the machine, locate and remove the main drive cog and lubricate the spring inside which can cause this problem. Upon inspection I became curious as to why this spring loaded lever-arm was hanging just next to the main cog but not touching it, the arm seemed to have something missing off the end of it as there was provision for some sort of bracket or attachment but nothing was there. I took photo's and headed off to the local spare parts and repair shop. He took one look and said the "Clutch Paul" was missing. $15 for a new one, fitted it myself, machine fixed working perfectly, job done."
Westinghouse washer, 2015 model, top loader keeps draining and no lights. Where is the reset button?
Your outlet probably goes straight down, Raise it at the back so that the water needs to be pumped up and then flow down.
Oct 23, 2016 | Westinghouse Washing Machines
Jul 21, 2015 | Westinghouse Washing Machines
Where is drainhole in westinghouse freestyle refrigerator
usually located midway of fridge compartment in center its a small one usually covered with a casing or cover sometimes? some are located at center sides or bottom of fridge. if u look under the fridge and see the tubing then follow it up and get an idea where that drain plug is?
Dec 04, 2014 | Westinghouse Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
My westinghouse washing machine LT809s keeps beeping at me and displaying the error code LL?
Mar 31, 2011 | Washing Machines
My westinghouse fridge model RJ532 Freestyle is leaking water on the floor
internal water drain is blocked - get very thin copper wire and unblock -
Jul 30, 2010 | Microwave Ovens
My westinghouse lt809s is very noisy while spinning. The part under the agitator looks 'corroded' and probably needs to be replaced. Suggestions?
Mar 12, 2010 | Washing Machines
How to unblocked drain in fridge, Westinghouse BJ434V-R
Defrost the frezer and then remove the grill .it has screws and also snaps in plastics on the sides.After this sometimes to get to the drain you also need to removed the back pannel.Always unplugged the unit before do any work.
Apr 17, 2009 | Westinghouse Refrigerators
0E Error
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse L2046NV Monitor
Washing Machines Logo
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
