We have black mold on our Vick 3100, how can we get it out, we have tried taking it apart, but the lead is holding it together.
Want to know if this is black mold or just mildew please help!!
Looks like mold just because its black doesn't mean its " black mold" that is dangerous 10_11_2013_8_26_21_am.png
Oct 10, 2013 | Electrical Supplies
Taking apart
Question about Brookstone Desk Fans: Slim Personal Desk Fan
Taking apart I took mine apart by removing the small screws that hold it together. my top fan cage was broken and loose. I glued it back together and the next day I just reassembled it and it works fine.. just look at what you are doing and dont FORCE anything common sense should allow you to do this... I am a retired auto mechanic 80+ years old and it did not give me any trouble until the e-clip jumped off, but I found it and all is well.. the screws are shiny and the case is black, so take them all out and lay in a pattern so you can reverse the pieces for reassembly..
Feb 19, 2013 | Brookstone Desk Fans: Slim Personal Desk...
Where are the mass air flow sensor located
Dre,
The mass air flow sensor [aka MAF] is located inside the tapered section of your air cleaner housing. Look for the round clamp with a lever that holds the two parts of the air cleaner box together. Loosen this clamp and take the air cleaner apart. You will notice that the tapered section has several wires going into it. Once you have it apart. Those wires will lead you to the MAF.
Nov 30, 2011 | 2000 Ford Expedition
The variable pulley over the motor has come apart. how do I put it back together?
There is supposed to be a snap-ring with covering a cap with a spring that compresses the pulley and holds it together. Maybe one of those pieces has broken or is worn out. Most online repair parts places have an exploded diagram of all the parts and where they go so you can identify a replacement.
Jun 06, 2010 | Delta Machinery Delta ShopMaster DP350 12"...
The check valve is leaking on my stanley bostitch cap2000p air compressor.I was trying to take it out to check it or replace it,but,it was so tight in there it broke off while trying to get it out. I need...
If you are talking of the clamshell cover, MANY plastic covers big and small have a few screws and then have molded "rods" on one side and a mating hole in a boss on the other. For these, one has to CAREFULLY pry them apart EVENLY so all seperate evenly..
Apr 28, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
How to disassemble a dewalt 14v battery
to take the battery apart you have to carefully cut it on the seam they are molded together. i am guessing you are hoping to replace the cells inside of it to repair the battery. I have done this a few times and can take quite a bit of patience and a good meter to figure out which ones are bad. make sure when you put it back together use some good qaulity abs cement so the battery does not come apart on you while using it.
Aug 21, 2009 | Dewalt DC984KA Factory Reconditioned...
I need to repair my fuel gauge, how do I take the dash apart?
Its all electronic, I'm guessing somehow the needle got flipped over the little black bar and you can't read the level anymore. To take the whole instrument panel out you need to first remove the molding that goes from side to side, it has the vents and blinker in it. Don't yank it out you have to remove the stubborn clips to the blinker and the instrument dimmer. There are just 2 screws at the top above the instrument cluster, the rest is clipped in. After then you will see there is 4- 6 little bolts holding the bezel in take those out and try to flip it over and pull the left side out first. Unhook the main harness and your good to go. Also it helps to put the steering wheel all the way down. Be careful putting the molding back in because once you break the clips it will wiggle and **** you off while driving, little squeaks :( . Hope this helps you out.
May 07, 2009 | 2000 Chevrolet Malibu
How do you take the dash apart to change the gauges?
Two screws hold the top of the molding in place, the rest of the molding that encompasses the air vents, hazard switch, and instrument dimmer use clips. There was 4 - 6 bolts that hold the instrument panel in place, after you take them out just unplug the harness and you can do what you want.
Mold
When you open the door note the differences in screws and around the hinge. There are 4 to 6 that hold the inner and outer panel together. the inner panel has the bubble window and the other the outer plastic. Once the screws are out the panels should pop apart, a slight edge holds them and if you want dis assemble the hinge too to make it easier.
Mar 13, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
