Question about Harman Kardon Audio Players & Recorders
Harman Kardon AVR 2600: On the rear panel inputs do not work,but on front panel inputs work well. Does anyone know to solve the problem? Thanks.
I did the processor reset,new software version installed. Doesn't work.
  • 44 Answers
SOURCE: Harman Kardon avr 1500 service manual
try here - http://www.harmankardon.com/product_support/support_detail.aspx?prod=AVR500
Posted on Dec 16, 2007
robotek
  • 1512 Answers
SOURCE: How to I reset my
Hi odysy
I got this from the manual page 43.
Resetting the Remote Memory
As you add components to your home-theater
system, occasionally you may wish to totally
reprogram the remote control without the confusion
of any commands, macros or ”Punch-
Through“ programming that you may have done.
To do this, it is possible to reset the remote to the
original factory defaults and command codes by
following these steps. Note, however, that once
the remote is reset, all commands or codes that
you have entered will be erased and will need to
be re-entered:
1. Press any of the Input Selector buttons 4
and the ”O“ button Hat the same time until
the Program/SPL Indicator 2begins to flash
amber.
2. Press the ”3“ button Hthree times.
3. The red LED under the Input Selector4
will go out and the Program/SPL Indicator
2will stop flashing and turn green.
4. The Program/SPL Indicator 2will remain
green until the remote is reset. Note that this may
take a while, depending on how many commands
are in the memory and need to be erased.
5. When the Program/SPL Indicator 2goes
out, the remote has been reset to the factory settings.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 29, 2008
WolfenHawke
  • 13 Answers
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
Posted on Nov 26, 2008
dunnbiker
  • 8546 Answers
SOURCE: Connecting Bose 901 series iv to Harman Kardon AVR 254
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Posted on Nov 30, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Connect pc
To connect your PC or Laptop to your Harman Kardon AVR 2600 you need to connect the HDMI cable output of your graphics card to one of the 4 HDMI inputs on the AVR 2600 receiver. The HDMI connector on the AVR 2600 labeled "HDMI Monitor" is on output and cannot be used as in input.
You need to select the corresponding input from the front of the AVR 2600 or using the remote. Next you need to make sure your have the HDMI output port selected on hour graphics card. This will probably not apply to your PC, but may require some settings from the function keys on your Laptop.
Note that you will probably need to also connect audio from your PC to your receiver as well. I would recommend you use HDMI cable with ver1.4 specification so that you have the best chance of getting audio over the HDMI. If you only get video, then run separate Toslink (optical) or RCA cables to get the audio to the system from the PC.
Jan 12, 2014 | Harman Kardon AVR 2600
HARMAN KARDON AVR 142 and APPLE TV
you must contact to the supplier manufacter via ONLINE chat and get support or call to the toll free for the consultation.
God bless you
Nov 25, 2013 | Harman Kardon Audio Players & Recorders
I have a Harman Kardon receiver Type AVR 500 RDS. Can I set it to 5ohz or 60 hz as I wish?
Should only set to frequency of your power supply otherwise may damage your receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
In hk avr 2600 there are 4 hdmi outlet. it didnt specify video in or out.
HDMI 1 through 4 are inputs; to the right is the single HDMI Monitor output.
Jul 25, 2010 | Harman Kardon AVR 2600
Short causing #3 & 4 fuses to blow
Hi Mopadge. I have the same problem with my avr210. Did you solve it? How? ... Thanks a lot.
Oct 23, 2009 | Harman Kardon AVR 210 Receiver
No sound,no video,front panel display will display.harman kardon
Check your audio settings on the main menu of the receiver. The audio input should be set to "auto" Next, make sure you don't have the unit in "6 channel input" mode or "direct" mode. This is usually a small button on the front panel. If you check all this and you still have a problem, post a comment and I will help you troubleshoot some more. Hope this helps
Jun 30, 2009 | Harman Kardon AVR 140 Receiver
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
