For the roland SJ-740, the yellow and black heads are completely missed from the test print, what should we do to fix this problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Ahmed?
Are the cartridge heads dirty, or clogged with old dry ink?
You may clean dried ink by using a lint-free cloth that is wet.
If you do that, make sure the cartridge head is dry before re-inserting it in the right place.
Good luck.
Posted on Dec 03, 2016
Print test page mfc210c
good day...If you done for cleaning the printer head, the the nozzle check have some missing squares in between, either black or all color, will theirs a problem on the print head...the solution is need to replace the printer head
Nov 28, 2017 | Brother MFC 210C All-In-One InkJet Printer
Roland sj 740 service manual
roland SJ-740 ink not filled, how to escape this setting
Mar 13, 2013 | Roland Printhead FOR SC-540 / SJ-540 /...
Roland fj-500 yellow dye ink printhead not printing
i have printer sj 160 st jet pro,problem in unrecovrable limit.and affiche ecran st jet pro sj???
Aug 02, 2012 | Roland Printhead FOR FJ-400 / FJ-500 /...
The print is faded . ther are three color bar missing on the test page ( yellow, black , and black).
Hi
Go into Maintenance in the Kodak Printer Management Program and try the Nozzle Check and Head Cleaning functions until the Test page prints clearly.
Head Cleaning might be necessary after every cartridge change.
I hope this helps.
Aug 26, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
MFC-5860CN poor print test results, missing squares on test resu
I am not sure these have removable/replaceable printheads. I have had issues similar to what you describe. If one of the colors is missing completely, then it is likely that the head dried out due to prolonged lack of ink. If only a few squares are missing but all the colors are present, then you stand a better chance of unclogging. Cleaning 5 times is nothing. I've had instances where it took 20+ cycles to get a jet working. There is hope.
Jun 06, 2010 | Brother MultiFunction Center MFC-440CN...
I have an Epson NX400 printer but the yellow and black ink test pages are showing gaps and missing lines. I replaced both ink cartidges twice and did the head cleaning and nozzle check but nothing seems to...
Try to print something that is pure yellow and pure black. Set it to BEST PHOTO. If you see gaps or missing lines, your print head could be clogged. You will need to use a cleaning solution to remove the clog.
Jan 16, 2010 | Epson Stylus NX400 InkJet Printer
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Jan 08, 2010 | Office Equipment & Supplies
Black ink will NOT work! NEW cartridge!!!
Your print head is already clog, if you can find chemical solution in your area,you can try to soak it without removing the print-head, on its parking put some solution then let it be there for 24 hrs then try printing,do this for three days if nothing happens,buy a new printer, because buying a print head is not practical, it almost cost the same as a new one.
Sep 18, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to print BLACK
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
    1. Press the Ink Management key.
    2. Use the up or down navigation key to select TEST PRINT.
    3. Press Set to confirm your choice.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
Cleaning the Print Head
  2. Use the up or down navigation key to select CLEANING.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
I hope it helps!!!
Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
MISSING COLOR IN MY PRINTS
try a test page first and see what that does
Aug 08, 2008 | Epson Stylus C46 InkJet Printer
k24674
jasbo
jasbo
