Question about Toshiba 50L1350U 50" 1080p LED-LCD TV - 16:9 - HDTV 1080p 1920 x 1080 - Audyssey ABX, Audyssey EQ - 3 x HDMI - USB - Ethernet - Media Player
Toshiba 50l1350u LCD TV. No power , No Sound, No Back light.
Have all voltage except 12v_Aud should be 12.56 reading 0vdc. L2-=1.18 reading 15vdc L1-=12.82 reading 19.2vdc every thing else reads ok. No Picture , No Sound, No Backlighting
    Master:
  • Toshiba Master
  • 708 Answers
Is there power to the AC outlet? Is that outlet a switched outlet?
Is there a factory reset switch on the TV?
Can't say any more. That's the best "blind guess."
i need more infromation to check
https://www.amazon.com/MALLCROWN-Splitter-adapter-Converter-splitter/dp/B01I4WJV5U/ref=sr_1_30?s=electronics&ie=UTF8&qid=1481872637&sr=1-30&keywords=HDMI+SPLITTER
Posted on Dec 16, 2016
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
A
Posted on Dec 03, 2016
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
Has sound ,no backlight, faint image
If you see a faint image, backlight is there, but its intensity is less. There are many reasons for this fault. From back-light inverter board to LCD panel should be checked for the fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 19, 2015 | Toshiba 50L1350U 50" Class 1080p LED TV
The rear lights and signal lights stop wrkng in my bros car,the windows dsnt go up nor down,and he have to reprogram the radio every time he gets in the car,fuses r ok and relay as well,what can be...
First thing is to measure voltage across battery (should be 12.6volts). If less than 12v then battery may be in poor condition and most things will not work properly. Before renewing the battery when the engine is running again check voltage across battery. It should read 14.4volts; this is the recharge voltage supplied by the alternator. If the voltage is less than 14v or the voltage supplied is intermittent then change the carbon brushes and perhaps the voltage regulator on the alternator (less than £10 on line)
Jan 23, 2015 | Cars & Trucks
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Sound no picture Samsung 58" Plasma TV Model #: PN58C550G1FXZA
if you are a tech in any aspect, try testing the power points Vs and Va voltages. If not present even with the other circuit boards disconnected the Vs is supposed to be 205v when disconnected like on my tv, it only had 12v and the Va which is supposed to read 56v was reading about 10v when the boards were connected (Y Buffers). With the boards disconnected the power supply will read high voltages, and when connected (try lower first, then try upper, then try together). If there is a voltage drop (significant) that particular board connected is the culprit. If the PSU doesn't read a large voltage like mentioned, try replacing the PSU first. Go to www.shopjimmy.com for parts
Nov 26, 2012 | Televison & Video
I have a 1994 ford taurus station wagon, the battery won't stay charged, the confusing thing is that the inside panel and door light works
you have a faulty alternator by the sounds of it, try this simple test, : test the voltage of the battery with the vehicle off with a simple multimeter, it should read just over 12v then test it with the car running, it should read around 14-14.5 volts if it still only reads 12v then your alternator needs replacing.
Sep 13, 2012 | 1994 Ford Taurus
Toshiba 50L1350U 50" 1080p LED-LCD TV - 16:9 - HDTV 1080p 1920 x 1080 - Audyssey ABX, Audyssey EQ - 3 x HDMI - USB - Ethernet - Media Player Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
