Question about Kodak ESP 5 Printer
Printed pictures have a somewhat reddish tint
  • 295 Answers
Go to kodak.com/go/itg 1.open printer access dooor and remove ink cartridges and printhead by pushing grey latch on printhead upwards and then taking printhead out insert it back into the carriage and then press bulls eye backward. print caliberation sheet.if problem persists,call kodak @ 1800 421 6699 and they will resend u a new printhead
Posted on Jul 21, 2009
My pictures have a reddish tint to them
If your pictures that have the reddish tint are taken indoors, the tint is likely caused by the lighting. You can set up a 'white balance" adjustment to fix that.
May 02, 2015 | Nikon D50 Digital Camera
My toshiba 61h71 has a reddish tint to it. Turned it off one night and it looked fine, next morning it got this reddish tint. Tried resetting the convergence but that didn't change the situation at all....
A Reddish tint means that the Green signal is missing. Does the on screen menu look normal? If so, this points to the signal source. The fact that this happend suddenly, I would check your cables first.
Using YUV?
If the TV's Menu also looks reddish then there is an internal problem with the display.
Good luck
Dec 30, 2009 | Toshiba 61H71 61" Rear Projection...
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
Red tint when photo prints
I you're shooting indoors with incandescent lights, it will show up reddish. Change the white balance in the Menu to expose for indoor lights, or use the flash - set to the green rectangle setting.
Nov 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Reddish tint on all pictires printed on my 4180. Same pictures prin perfectly on hp 7260.
You are experiencing a printer cartridge problem. Sounds like some of the colors in the print cartidge have run out, either that or the nozzles are clogged. Run a nozzle check from the printer software, if it does not fix, try a new color cartridge.
Let me know how it works out for you.
Sep 15, 2008 | HP Photosmart 4180 All-in-One Printer
Green Tint Over Entire Printed Picture
I had a very similar problem and found out that the problem was the quality of paper I was using. Remember, a photo printer is expecting high quality results. Cheap, low quality paper will not accept the ink as well as higher quality paper. I can't guarantee this will solve your problem but I have not had any green tints since switching to a higher quality photo paper.
Jun 27, 2008 | HP Photosmart 8150 InkJet Printer
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color out of wack
There are only two things can cause that problem out of value resistors on video stage. or weak picture tube . the first one 60 to 80 dls dependig on the tech ,at shop service 125.00 if is the picture tube more than 450.00 good luck and let me know thanks
Jun 12, 2007 | RCA F32649 32" TV
Kodak ESP 5 Printer Logo
140 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
