Question about i-mate PDA2k Pocket PC
Depolution fault peugeot 407 2.0 hdi
I have had a new fuel pump and egr valve fitted to my peugeot 407 2.0 hdi and every time i start i get minor engine fault light saying depolution system faulty. i have had it reset three times and after 20 miles or so it comes on again. computer says learning system but this is 600 miles now, surely it should not take more than this. help please this is doing my head in.
Need help SFHetal@aol.com
Posted on Jul 20, 2009
How much did it cost you to replace that bits on? as i got on my car aswell same this saying and i also got the engine light while i driven from canvey island to leicester
Posted on Feb 01, 2010
White smoke from my exhaust on my peugeot 407 hdi sw and says depolution system faulty
Try to replace the dpi filter...then follow this method to "remove" the code after you replace the dpi filter:
try to reset the maintenance computer. To do that, remove the car key. Press continusly on the "check" botton on the dash board. Put the key in and switch to on, but don't start the car. Wait 10 seconds (on screen 10-9-7...-0). Nowthe maintenance computer go to 20,000 and erase all old warning report. If the engine light and the "depolution" warning keeps showing up after that, it means there are still fuel related problems. make sure you are using the right fuel and fuel filter!!!. Don't use cheap fuel/filter, like at supermarket store, etc..get them from real gas station/auto part store...
Nov 27, 2013 | Cars & Trucks
My peugeot 407 hdi sw is saying depolution system faulty showing engine management light and blowing smoke from exhaust when started
chek for a collapsed catalytic converter and/or a clogged exhaust system...if it only smokes when 1st started, it could need valve seals...chek for clogged charcoal canister too if equipped...
My peugeot 407 hdi 1.6 depolution system faulty came on and engine managment light . Car blew smoke now won't start what is it
could be a lot of things, blocked dpf filter, egr valve stuck open, injector stuck. need to have it plugged in to see what faults the ecu is holding.
My peugeot 407 hdi 1,6 sw depolution system came on and engine managment light ! It blew smoke so I stopped car won't start what causes this
Sorry dealer only and its going to cost about a 1000 pounds at least although i suspect that the timing belt broke as they still start even with this poloution light on
How to set ignition timing on a 407 peugeot
i have a peugeot 407 hdi 2.0 turbo 16 valve engine and i wont to now more about timing markes where is
Jan 22, 2013 | Peugeot Cars & Trucks
Peugeot 206 1.4 hdi has developed a fault where the engine will not start.After leaving the car rest for a couple of hours it will not start .I have to manually bleed the system and the car will start and...
expensive to repair properly,quick fix??? fit two non return valves ,one in the feed and one in the return to the injector pump ,weither conventional pump or common rail pump .this will cure your problem and its cheap to do ,two valves (observe direction) in the lines .works every time on any diesel engine weither its plant or road use
Oct 18, 2009 | 2005 Peugeot 405
i-mate PDA2k Pocket PC Logo
1,528 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Bilal Ahmed Qureshi
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
