Where is the reset or fuse on the ultima 65 laminator?
3 Suggested Answers
  • 11 Answers
SOURCE: My ultima 65 laminator is not sealing well on the
By "upper tension" do you mean the hex screw located inside the left panel? If you tighten this until there is no space between the heat rollers it should eleminate the problem. If it is continues to loosen, back the screw out, apply a small amount of locktight to the threads before replacing the screw.You can find locktight at any hardware store usually in the Paint section near the glues. Hope this helps. Good luck
Posted on Mar 11, 2011
SOURCE: gbc heatseal ultima 65 won't turn on. It shut
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Posted on Dec 18, 2012
Replacing the fuse in an ultima 65 laminator
Hello, I found the service manual for the laminator.
https://www.manualslib.com/manual/838190/Gbc-Ultima-65.html?page=42#manual
page 42 shows the left side blow out. #16 is your 15A circut breaker, located on the underside of the left rear of the machine. Page 43 lists what all the numbered parts are if you need to know anything else. It doesn't give explicit instructions on how to remove, it but it shouldn't be difficult. Be gentle but firm and don't jerk it out or you might damage the connectors. Hope this helps.
Sep 27, 2017 | The Office Equipment & Supplies
Where is the fuse?
The Circuit breaker is located on the underside of the machine near where the electrical cord goes into the laminator. West Laminating Svcs 405-324-6092
Aug 12, 2015 | Gbc HeatSeal Ultima 65 Laminating System
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Top roller of GBC ultima 65 not heating
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
westco laminating services....405-324-6092
Oct 23, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Will not come on .does it have a reset button
Make sure safety switch on tray is close and protected shield is close also.
Oct 15, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Gbc ultima 65 won't heat up.
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
Oct 02, 2013 | Gbc HeatSeal Ultima 65 Laminating System
223 people viewed this question
k24674
jasbo
jasbo
