Question about Refrigerators
Set timer &thermastat - Refrigerators
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Ok, what kind? Electrical or mechanical? Home or auto? (Auto comes preset)
Posted on Dec 02, 2016
Top thermastat has no voltage?
Are you getting 240v to the element ? If not it may be the timer , the centrifugal switch on the motor or a fuse . start by testing continuity in t he fuse then test timer .
GOOD LUCK
APPLIANCES R'EN
Dec 08, 2013 | Kenmore Dryers
Does the control thermastat have anything to do with the freezer on my refrigerator getting cold but not freezing
If you remove the evaporator cover and look at the frost on the evaporator is it fairly even frost from top to bottom? If you don't have frost on the bottom half of your evaporator then you have a freon leak. Do you have a model number for your unit?
Mar 15, 2013 | Whirlpool Refrigerators
My Kenmore Dryer stops before the time I set is up.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
Mar 12, 2010 | Kenmore Dryers
Why wont the timer wont go off
Timer is not going all the way to off,replace the timer,and cure the problem.
Sep 16, 2009 | Whirlpool LER5636P Electric Dryer
My electric oven wont heat up
check the breaker box first, turn breaker off then on. then try oven again
check the timer, sometimes the timer gets set to delay and oven won't work
second, with oven off trace entire element with finger to see if there are any burnt spots.
if no burnt spots found, there may be a burnt wire leading to element in the wall behind
please, don't forget to rate my solution.
thanks
Jun 22, 2009 | Ovens
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Goodman heater blower runs on own won't stop after flame shuts of
bad blower relay or timer. replace board.
shorted thermostat wires. check.
Feb 19, 2009 | Goodman GMS90703BXA Heater
Refrigerator blowing warm air.
check the thermastat with power off remove one wire on the thermastat and read across the two terminals of the thermastat with an ohm or resistance meter if set to highest setting on the thermastat you should get a resistance reading if you don not the thermastat is vad
May 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Kenmore dryer
check the heatingelement and the element high limit thermastat
the high limit thermastat is on the left side of the element housing and has two red wires connected to it
with a ohm meter the element and the thermastat will read contunity
i wuld start there
Apr 20, 2008 | Dryers
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
