Question about Dodge 1997 Ram 1500
What dose a crank sensor looks like on a 97 dodge ram 1500
A diagram of a crank sensor on a dodge ram 1500 pick up
    Top Expert:
  • Dodge Master
  • 8,213 Answers
Dodge ram codes
Tune up, coils and wires.
Dec 01, 2017 | Dodge Ram Cars & Trucks
Codes P1683 and P1597 on 98 dodge ram
anything from a pin hole in a vacuum hose to fuel pump or filter issues so many things it could be but u can look up ur codes online
Jan 15, 2013 | 1998 Dodge Ram 1500 4WD
My 97 dodge 1500 ram truck 5.9 starts jerking when driving,when idle the truck starts rev up and wants to go. What could cause this. Engine light has just came on.
Stop by any good parts store (Autozone, Advance, etc...) and have an OBII scan done (fault scan) They do this FREE - this will identify what's troubling your truck. It sounds like a vac leak or crank sensor but that's speculation... Have scan done then you'll know what to look for and you won't be throwing parts at it.
Mar 31, 2011 | 2008 Dodge Ram Pickup 1500
I need a diagram of a 97 dodge 1500 distributor cap??
Not sure of your engine size so please pick the appicable diagram:
2.5L Engine Firing Order: 1-3-4-2 Distributor Rotation: Clockwise
3.9L Engine Firing Order: 1-6-5-4-3-2 Distributor Rotation: Clockwise
5.2L and 5.9L Engines Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Nov 20, 2010 | 1997 Dodge Ram 1500 Club Cab
I have a 97 dodge ram 2500. Sometimes my transmission doesn't work good and also my speedometer doesn't work at all.
dose the trans act up at the same time the speedo cuts out if soo you definatly have either an intermittent speed sensor problem of wiring in the speed sensor circuit. speen sensor is located on the extension housing of the transmission (2wd) ot back of transfer case (4x4)
Oct 30, 2010 | 2000 Dodge Ram 1500 Truck
1999 dodge ram 1500 5.2 dies while driving
Dodges have a high rate of failure in the engine ecu. If you can find you 5v supply that feeds the sensors. Ohm it to ground If it dose ohm out (shorted to ground) unplug your ecu and recheck.
May 25, 2010 | 1999 Dodge Ram
97 dodge ram no spark
then i would replace whats called the hall effect sensor its that black plastic plate you see when you take dist cap off. just pull rotor and lift up the sensor.dist cap is what holds it on.also under the sensor will be a stamped sheet metal piece that looks like the top of a castle wall. make sure its not loose on the shaft.if it is then new dist will be needed
May 09, 2010 | 1997 Dodge Ram 1500 Club Cab
Dodge 1997 Ram 1500 Logo
109 people viewed this question
Top Dodge Audio Players & Recorders Experts
J.D. Browning
J.D. Browning
kli99gunrunn
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
