No video from tv I have replaced the mainboard,t-con and backlight
Lc-43le653u
    Top Expert:
  • Televison & ... Master
  • 79,865 Answers
I would think that was enough wasted money and you should just go ahead and stop the bleeding and replace the TV, new ones are very cheap, that goes double in this season
Posted on Dec 02, 2016
I have a Samsung un32eh5300fxw with a non-working backlight. I'm unsure on this model has the LED backlight driver is built into the power supply, mainboard, or the t-con board.
Take off the rear and check the high voltage circuit. 120 volts enters follows by a fuse into a small high voltage transformer, then on the other side a capacitor (100 uf rated 450 volts). Check the DC voltage here. I got 380 volts. Should be at least 390 volts or more. If anything less, you will need to replace this capacitor. I used two capacitors from some old power supply - 150 uf and 220 uf rated at only 400 volts connected them in parallel and TV is back to normal.
Jan 12, 2018 | Samsung Televison & Video
My Sharp LC-50LB261U tv screen went black but i still have sound. i replaced t-con board and power supply board and have same problem. can you help?
I don't have a service manual for that set so I'm only able to help on a limited basis...Have you tried the flashlight test?...if the backlights are out then it could be a backlight driver board if it has one? or defective LEDs. See what you have for voltage going into the panel LED's
Oct 18, 2017 | Sharp Televison & Video
LG 55LW5600 problem Symptoms: no audio, no video, no backlight.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 12, 2017 | LG Televison & Video
I bought a slightly used sharp aquos tv LC-43LE653U with no remote. I then bought a sharp lcdtv GJ221-C remote off amazon. The tv is on but the remote won't work. Thoughts?
Check the remote by pointing your cell phone camera at it, when you press a button on the remote you should see the IR diode flash a violet color.
Mar 14, 2017 | Sharp Televison & Video
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
Feb 27, 2017 | Samsung Televison & Video
Hi, I have a faulty Samsung UE40F5500 LCD TV with no picture issue. Would a new mainboard fix the issue?
Hello Check the capacitors, if they are swollen on top, replace them
Good luck
Apr 25, 2016 | Samsung Televison & Video
T-con board or maim Board issue? Disconnected T-con from the main board and got back light! sharp lc-55le55ou
Hook the Tcon cable back up and do this. With a program running on the TV, shine a flashlight in the screen. If you can't see movement from the program, then the Tcon board is bad. you can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 02, 2016 | Sharp Aquos Televison & Video
How do i test a backlight for a led tv
Testing TV Backlight LEDs - YouTube
? 4:44
https://www.youtube.com/watch?v=eEJoPCa7Kt0
Jan 24, 2015 - Uploaded by swappart.com
... explaining easy way to test individual LEDs on a strip from aTV backlight. ... Sharp LC-60LE820UN TV - LED Strip Testing - Long Version ...
IT02 - How to Test LED Backlight - YouTube
? 0:55
https://www.youtube.com/watch?v=YmSI2N6BGPA
May 20, 2011 - Uploaded by LCDPARTS
How to use IT02 to test Laptop screen LED backlight.
LST04-TV, How to test LED TV screen - YouTube
Dec 26, 2015 | LG Televison & Video
My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Nov 20, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
