Question about Toro Garden
The plug on my Toro power blower vac got super hot and melted the inside of the extension cord plug. what happened?
    Welcome Back:
    Visited the website for 2 consecutive days.
It appears that for some reason, the connection at the extension cord, overheated. Could be caused by: 1. a problem with the vacuum unit (bearings, jamming up, something like that)
2. The extension cord itself was defective. Could have been abused, moisture could have broken down the "contact" or the point of contact or blades of the extension were loose and caused excessive current draw at that point, overheating the device.
Or, it could have been a factory fault with the extension.
Plug your blower into a good receptacle, and see how it runs. If it is
sluggish or not coming up to speed, the problem could be in the unit.
Check manufacturer's recommendation for extension cord size and length.
Posted on Dec 02, 2016
    Welcome Back:
  • 24 Answers
Not enough power to it,the vac overloaded the circuit.the extension cord might be too long or too small
My Toro power blower vac plug got so hot and burned the inside of the extension cord so it melted onto it.
Obviously, that power cord is now shot. But, if you are pretty handy and very confident, simply splice the cord. Make sure you hook up the wires to the correct ones and plug it in make sure it is all electrical tape back together so the wires have absolutely no chance of touching each other, and if that does not work, I would say that there is a defect with the Toro
Dec 02, 2016 | Toro Garden
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Will not start . This is an electric blower.
There is an interlock on the air inlet (where the leaf chute fits when in vacuum mode or a grille fits in blower mode.) If either of those items is not installed and locked in place (by rotating until it clicks) the power will not go on. If the above devices are correctly installed and the unit does not run there is a problem with the plug that the extension cord attaches to, the switch or the motor.
Dec 19, 2009 | Toro "Toro" Super Blower/Vac
I have a 51592 Rake and Vac Toro blower. Yesterday, when using the blower (all I use) the cord got hot and started to melt both the blower cord and extension cord; First time ever I have had this problem.
If it is getting hot enough to melt the electric cord and the extension cord, get rid of it. The over-heating is most likely from the brushes in the motor, which means, unless you are a licensed electrician or know one, the unit should be scrapped. Replacement parts for these electric blowers are priced such that it is cheaper to buy a enw one than to fix the old one.
Nov 21, 2009 | Toro Blowers Rake and Vac - Electric...
I have a Toro Super Blower Model 51591, and need a replacement power cord. None of the online catalogs show this as being for sale. Can you recommend an alternate source?
You probably won't find one (at least I haven't). But if your cord was damaged in the same way as mine (at the base, where it goes into the unit), I will be happy to share with you DIY fix that worked for me. Email to radist2000@yahoo.com.
Jul 16, 2009 | Toro "Toro" Super Blower/Vac
My Toro Super Blower works fine & then I notice smoke at the cord
sounds like your blower is drawing to many amp`s for the cords your using for this
Feb 13, 2009 | Toro Super Blower Vac
Toro blower model 51591 electrical prong melted. help!
The answer is wrong. This model and other Toro blowers with the plug built into the body (as opposed to the new design with plug on cord) has this problem when the plug does not completely mate with the cord. This happened to mine too. Unfortunately Toro does not provide a replacement part. HOwever, perhaps the new designed cord will fit as a replacement, but I am unsure of this. When my plug melts completely I will try that.
Dec 22, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
57 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
