Question about Toro Garden
My Toro power blower vac plug got so hot and burned the inside of the extension cord so it melted onto it.
  • Brad Brown Dec 02, 2016
    Hi Pamela Bills, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What model number is it
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Obviously, that power cord is now shot. But, if you are pretty handy and very confident, simply splice the cord. Make sure you hook up the wires to the correct ones and plug it in make sure it is all electrical tape back together so the wires have absolutely no chance of touching each other, and if that does not work, I would say that there is a defect with the Toro
Posted on Dec 02, 2016
The plug on my Toro power blower vac got super hot and melted the inside of the extension cord plug. what happened?
It appears that for some reason, the connection at the extension cord, overheated. Could be caused by: 1. a problem with the vacuum unit (bearings, jamming up, something like that)
2. The extension cord itself was defective. Could have been abused, moisture could have broken down the "contact" or the point of contact or blades of the extension were loose and caused excessive current draw at that point, overheating the device.
Or, it could have been a factory fault with the extension.
Plug your blower into a good receptacle, and see how it runs. If it is
sluggish or not coming up to speed, the problem could be in the unit.
Check manufacturer's recommendation for extension cord size and length.
Dec 02, 2016 | Toro Garden
I have an lectric Homelite blower/vac. It worked well for 1/2 hour. I turned it off and when I wanted to turn it back on, it started but stopped within a minute. I tried three different extension cords...
I could be a variety of things. Did you have a very long cord on it? did the cord loosen the plug? are you sure the outlet is still good, Also you may need to wait a few hours for a thermal reset to reset.
Aug 08, 2011 | Toro Electric Ultra Blower/Vac 12 Amp
It looks like the plug on the blower melted slightly now the blower doesn't work can it be repaired
Parts are few for these machines (all I found was the blower tube). That being said, you can carefully cut off and remove the faulty male plug and replace it with a repair piece like you would add onto a damaged extension cord (outdoor type). They are made of plastic, but are fairly sturdy. Just carefully cut away the old male connector (the shrod isn't really necessary and remove the wiring from it. After purchasing the male-type plug replacement, rewire it and you will be set to go. To eliminate the male cord and the female end of the extension cord you will use from pulling apart when in operation, just loop the female end cord around the cord of the blower and it will hold in place.
Mar 19, 2011 | Toro 51585 Power Sweep 7 Amp 2speed...
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
When we started using toro leaf blower this year the extension cord started smoking and the plastic started to melt. Is it the leaf blower or extension cord that's faulty. Both are fairly new.
You must use at least a 12 guage extention cord . Your current cord mostlikely can not handle those amount of amps for long duration of time.
Nov 07, 2010 | Toro Garden
Will not start . This is an electric blower.
There is an interlock on the air inlet (where the leaf chute fits when in vacuum mode or a grille fits in blower mode.) If either of those items is not installed and locked in place (by rotating until it clicks) the power will not go on. If the above devices are correctly installed and the unit does not run there is a problem with the plug that the extension cord attaches to, the switch or the motor.
Dec 19, 2009 | Toro "Toro" Super Blower/Vac
I have a 51592 Rake and Vac Toro blower. Yesterday, when using the blower (all I use) the cord got hot and started to melt both the blower cord and extension cord; First time ever I have had this problem.
If it is getting hot enough to melt the electric cord and the extension cord, get rid of it. The over-heating is most likely from the brushes in the motor, which means, unless you are a licensed electrician or know one, the unit should be scrapped. Replacement parts for these electric blowers are priced such that it is cheaper to buy a enw one than to fix the old one.
Nov 21, 2009 | Toro Blowers Rake and Vac - Electric...
Motor smokes
If an electric motor is smoking, most likely it is in the process of burning out the windings in the motor. This usually starts from using an extension cord that has too small a wire or a cord that is too long. when you do thid you are forcing the motor to pull more amps than it should to make up for the voltage loss in the cord.
The fuel for the electric motor is a term called watts. Watts equals volts times amps. If the voltage drops then more amps are needed to feed the motor enough watts. This caused the motor to over heat and this melts or breaks down the insulation on the windings. When this happens the motor starts to short out and once this happens then you can not save the motor.
Electric lawn equipment should be used with #14 or #12 (never use #16 or #18 gauge ) guage extension cords and should not be used with cords longer than 50 feet. Also you should not run the equipment more than 10 minutes with out a 30 minute rest.
Aug 27, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
My Toro Super Blower works fine & then I notice smoke at the cord
sounds like your blower is drawing to many amp`s for the cords your using for this
Feb 13, 2009 | Toro Super Blower Vac
Toro blower model 51591 electrical prong melted. help!
The answer is wrong. This model and other Toro blowers with the plug built into the body (as opposed to the new design with plug on cord) has this problem when the plug does not completely mate with the cord. This happened to mine too. Unfortunately Toro does not provide a replacement part. HOwever, perhaps the new designed cord will fit as a replacement, but I am unsure of this. When my plug melts completely I will try that.
Dec 22, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
114 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
