Question about Danze Home
Danze shower on off valve leaking. How do i repair it?
    Welcome Back:
    Visited the website for 2 consecutive days.
This a common problem with most shower valves.After time the internal parts of the valve wear and need to be replaced. You can purchase a new shower cartridge for about $50.00 at your local hardware or on line. Be sure to turn off the water before removing the old cartridge. Install instructions should be included or go to Danze.com
Posted on Dec 02, 2016
My Danze showerhead runs even when turned off
try cleaning the inside of the valve with 1500 grit wet sandpaper. and then put a lot of waterproof plumbing grease in there and also on the cartridge. sometimes you can get a build up of hard water inside the valve body and that will cause leaks. just dont over do it with the sandpaper and dont anything more abrasive than 1500 grit.
Nov 26, 2012 | Danze D135300BT Single Handle 3/4 Volume...
How do I repair a Danze single handle tub and shower faucet which leaks benind wall when water is on but does not leak when is off?
this is caused because its not in the value...its either in the shower head seal or pipe or the tub spout...you have to turn it on and some how watch and see where it is coming from....sometimes you can pull back escushion from shower arm and look with flashlight when it is running and if you see leak where arm is screwed into pipe...unscrew and reseal with teflon tape and tighten...if not you will have to cut wall behind system and watch for area of leak...good luck
May 02, 2012 | Danze & Single Handle Tub And Shower...
Danze UPC tub/shower valve leaks constantly at tub spout
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
Aug 15, 2011 | Danze Home
Shower valve has a thumping sound when other faucets or toilets are turned on and off.when you turn shut offs to danze shower valve off sound goes away.could this possibly be the plunger in the valve?
Vfiippone,
I have the same issue with a Danze Sonora shower Valve. I called Daze and they sent me a new cartridge. After installing it I have the same problem. I also put a surge arrester on my toilet which had little effect. If you find the cure please post it.
Nov 04, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Shower valve leaking
here is the link to the pdf file http://www.plumbersurplus.com/pdf/07606.pdf
If you cant get directly to it from the above link, go to plumbersurplus.com/prod/danze-D51001BNT then click on "documents"
Apr 04, 2009 | Danze D510011BNT Brushed Nickel Melrose??...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Home Logo
140 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Chris Brown
Chris Brown
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
