Does pilot need to be relit every time I turn off glo warm gas heater?
    Master:
  • 383 Answers
No-- it should normally keep the pilot burning...
How about we learn a few things together, and see what to do next:
1.) Does it have a little device right next to (in the path of..) the Pilot flame, that is supposed to stay HOT (and thus be safe for the Pilot gas valve to stay open/'on')-- This is called a Thermo-couple.-- (Actually a very low voltage generator, that tells the gas valve it is safe to let gas flow.)
Here is a link to a Thermo couple for GloWarm heaters-- not sure if this is your exact model or not -- but it may help you know what I am talking about?)
http://www.ebay.com/itm/like/140878605243?lpid=82&chn=ps&ul_noapp=true
2.) How old is the Thermo-couple?-- and is it dirty from soot build up?-- It can be polished-- that might help.
3.) THe Pilot flame needs to be just slightly in the path of the flame, so that it generates sufficient electrical power to keep the gas vale 'on'.
Any questions from the points listed above?
Hope this helps-- Mack B.
Posted on Dec 02, 2016
Installed Dyna Glo BF30DTDG-1 NG Heater, pilot / gas knob won't turn-why?
Spay some wd40 on control knob some times they are still to move .
Dec 05, 2016 | Dyna-Glo Heating & Cooling
Glo warm gas wall heater
Sounds like a bad thermocouple. When they go bad, they won't open the gas valve when switched from pilot to on.
Dec 04, 2013 | Heating & Cooling
I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
Nov 29, 2010 | Desa International GWRP16 16,000BTU LP Gas...
The pilot light was out on our gas heater, we relit it but the air is not warm after 20 minutes.
one thing the pilot does is to heat the thermocouple sensor so it can tell the gas supply valve to that there is a pilot and it can open safely. thermocouples do need to be replaced from time to time. they are around $10.00 and not terribly difficult to change. look for a metal cylinder in the path of the pilot flame. more rarely, the gas valve itself will need to be replaced. it is more expensive however.
Feb 12, 2010 | Heating & Cooling
Glo warm heater
the regulator IS not only the issue, but it's a major safety benefit,..the pilot flame is non adunstable..get a cheap regulator(like the ones for the outdoor bbq's)
Mar 16, 2008 | Heating & Cooling
Lighting a glo warm heater
Is this a new heater or have you had it awhile? If new, yuo may have air in the line that will need to be bled out. The heater has a gas valve with a pilot setting on it. Make sure the gas is turned on. Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When uou release the knob, the flame should stay o. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on.
Nov 29, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
