Question about Dynex Televison & Video
I'm hooked to cable tv on my dynex 37 inch tv but cannot change the screen size or time. Why
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
This may be time to find and read the user manual. Please don't be insulted. If you have lost yours, you may likely find one in a PDF format online. In a search engine type quotes, like (below using your info...)
"Toshiba TVDC567" "Owners Manual" +download
Posted on Dec 03, 2016
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
How much will it cost me to e replace a dynex lcd 42 inch flat screen tv
Dynex is not a seller of TV's up to that size. The closest I could find is a 37" Class / 1080p / 60Hz / LCD HDTV on amazon.
You can see it Here: http://www.amazon.com/DynexTM-Class-1080p-60Hz-HDTV/dp/B004896RCY/ref=sr_1_5?s=tv&ie=UTF8&qid=1306529090&sr=1-5
May 27, 2011 | Televison & Video
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
Got a 32 inch dynex tv how do you get the direct tv to work on it
the tv or direct tv comes with the hook-up cables. try one of those and remember the TV input where you plugged in the direct tv box then on TV remote or front function button change the input. :)
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
Progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
Jun 18, 2009 | Televison & Video
Where/what do I buy to mount my tv on the wall?
You can buy almost any wall mount for it, just be sure of 2 or 3 things... 1st the location, you have to screw some rather large bolts into the wooden studs in the wall so check where it will be located... 2nd weight and size... You want a mount that will be able to hold up the weigh of the TV, usually the size will be between 32" to 40" (various mount sizes) Just make sure the size 37" is between the size lengths... and 3rd that it has a "tilt" adjustment... due to the placement of the TV you might get either reflection off of a light source or you may need to change the angle so that you can see it better on the wall... Hope this helps out and if in doubt be sure to ask someone at the store you buy your equipment (TV, Audio, Games, etc)...
Mar 27, 2009 | Dynex DX-LCD37 TV
Toshiba 37 inch TV
do you have the satellite hooked up through the coax cable if so that could be the problem you will have to manually set the settings with the remote. always make sure you have only one thing hooked up at a time. if you have cable and satellite dont hook up both it makes the picture lousy see the owners manual i think its page 58 or somewhere close to there.some times if both are hooked up it will not work at all.
Dec 10, 2007 | Toshiba 37HL67 37 in. LCD HDTV
Televison & Video Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
