Question about Samsung Computers & Internet
I have a Samsung 50 LED Smart TV, model number UN50J6200. It has started flickering. It's currently plugged directly into the wall.I see a lot of quick fixes for every size, but not ours.
Can you tell me what jumper needs to be cut on the back of the TV to resolve this problem? Thanks! Tony Curto recently answered this by saying Do not cut any jumpers. Your board is failing. So my next question is this--Where can I get a board for this TV? And do you know how much it cost? And is it pretty much plug and play?
    New Friend:
  • 29 Answers
Hello, here is a link to a site to help you find part replacements for your samsung UN50J6200 LED TV,
you would have to be more specific on your model number, which will be located at the back of your tv.
Posted on Dec 04, 2016
  • 624 Answers
SOURCE: Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Posted on Jan 08, 2007
  • 1226 Answers
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Posted on Feb 26, 2008
  • 13 Answers
SOURCE: Compaq for Evo D300 Motherboard
The link is helpful but does not show how to wire the power switch, power led, hdd led and reset switch. Need this information to transfer board to another case.
Posted on Apr 05, 2008
  • 27 Answers
SOURCE: user manual
seek at for downloading >>register for free and other use the nxt >nick= erolkane >pass=sendemileyla (my own) dont forget to vote for the driver after using it ;)
Posted on Oct 21, 2008
  • 2229 Answers
SOURCE: turn off power and reinstall the jumper in normal mode position
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Posted on Feb 12, 2009
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
I have a Samsung LN46A650 LCD TV and just recently I started getting an electrical popping sound while watching the TV. When this occurs, there are 2 light white bands across the screen and then it is...
without a standby error code or maintenance mode fault detection code, it's hard to say.
if you are looking for possibilities, then start with targeting the Ysus board as a possible culprit along with the Zboard buffers. the band would lead me to think buffers are having issues.
Nov 24, 2013 | Samsung LN46A650 46 in. LCD HDTV
Trys to start while it is runing
I'm gonna need more information before I can give you a good valid answer. But for now i can tell you that if you've recently had a starter r/r or an ignition problem resolved or should i say an attempt at resolved, sounds to me that your seliniod wires or your ignition wires are not hooked up to the correct places. Its an easy mistake if youve never dealt with or repaired anything to do with the starting system(ignition) If you could provide me with the year make and model of your vehicle and include a little history as to when this problem started and what prior repairs youve just recently had done I'm sure I can better answer your question and give you a perfect solution. The fixya team will be happy and waiting to hear back from you.
Nov 22, 2010 | Pontiac Sunfire Cars & Trucks
Cuts off
Check the rider safety switch under the seat for proper operation.
A small jumper wire around the switch will tell you if it is indeed bad - if when you try again - it does not stall.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a big problem....i have an acer aspire 6530g and i recently installed a bios update which screwed up my i went to reinstall windows xp pro and it wont reconigze any of my partitions..i hit...
You need to have your motherboard resetted. There is a jumper on the board that say reset. Move the jumper to that and turn it on for a few seconds. Then turn off and put the jumper back to the original spot.
Oct 17, 2009 | Acer Aspire 6530-5143 Notebook PC
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional Upgrade...
I have recently purchased the NX2 software, and as recommended changed the setting on my D70s from JPEG fine to NEF (or Raw). In the past I have downloaded files using either Nikon View software or the...
Try Nikon Transfer at
You can also download a codec from Microsoft that makes Windows recognize NEF files.
Dec 17, 2008 | Nikon Cameras
New (used) hard drive
Just remvoe the cd rom and then try to install your hard disk. if it is detected than it means there is a problem of setting master and slave in jumper.
So just check again your jumper settings and read the front side description of hard disk for jumper settings.
Aug 13, 2008 | Compaq Deskpro 2000 PC Desktop
Computers & Internet Logo
82 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
