Question about Cameras
Camera says, Lens Error? - Cameras
    Top Expert:
  • Cameras Master
  • 8,211 Answers
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
I have a canon Powershot A480. It keeps coming up with the faultLens Error Restart camera. How do I do this
Service & Support Issue: Camera displays "Lens error, restart camera" on the LCD monitor.
Solution: Possible solutions for a Lens Error message PowerShot A480.
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Please click here to set up service for your camera online.
Jul 25, 2010 | Canon PowerShot A480 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
This error occured when lens is prevented from properly extending or retracting. When pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed due External shock or liquid, sand & dirt etc. enters the camera.
Avoid applying pressure to the lens and surrounding area:
1) Do not touch Lens while shooting.
2) Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera OFF and then ON again then your device need to be repaired.
Have a nice day Rating the solution is highly appreciated.
Mar 06, 2010 | Canon PowerShot G9 Digital Camera
Lens error,restart camera
This error occured when lens is prevented from properly extending or retracting.when pressure is applied to the lens or the area surrounding the lens while handling the camera.
  • Do not touch Lens while shooting.
If you cannot clear the error code by turning the camera off and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Feb 28, 2010 | Canon 8.2-Megapixel Digital Camera Lens
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD500 / IXUS 700 Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
