Question about Home
Atomic clock keeps losing outside temperature
I remove the batteries and let the clock sit for 10-15 minutes. Upon inserting batteries both inside and outside temperatures are displayed after about 8'minutes the outside temperature disappears and only dashes are displayed. This has happened 3 or 4 times when trying to set it.
    Top Expert:
  • 8,304 Answers
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Outside temperature not working on Atomic Clock (was working last night). Changed the batteries in both the outside transmitter and the clock tonight. Clock reset within minutes, but the outside...
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | SkyScan 86709 Atomic Wall Clock
My atomic clock won't show the outside temperature and I can't get it set for regular time, it only shows military time. How do I fix these two problems?
Hi
If you have lost the outside temperature on the clock display then do the following:-
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappears.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
Also check the link bellow:-
http://www.ehow.com/how_4597931_set-atomic-clock.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 31, 2011 | Office Equipment & Supplies
After changing batteries in both the outside sensor and the inside clock I no longer receive a reading for outside temp.
I have a thermometer with an outside sensor. It's necessary to remove both batteries, wait a few minutes, then replace batteries - sensor first. It may take a few minutes for the inside clock to pick up the signal. If it doesn't, try again with new batteries.
Dec 21, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Atomic Clock Daylight Savings
Your clock may need to receive a signal indicating the time change. You can try moving it to another room, or outside to see if it reads the signal. Mine didn't, so I removed the battery and reset the clock. It wasn't obvious how to do that and I didn't save the owner's manual but upon close inspection there was a tiny black button (that looks like where you would lift a cover for a battery) and pressing it allowed me to adjust to the correct time. It is a "Sharp" bought at Target a couple of years ago.
Mar 10, 2009 | La Crosse Technology WT-2171-UCS Digital...
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Apr 21, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Home Logo
1,529 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
