Question about Husqvarna Garden
Replacing a chain adjuster on 272XP Husqvarna.Sheared the bolt. Purchased the correct part.I cant make out how to put the plastic adjusting nut on the screw from pic in the manual.Lil help? thank you!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
The square nut should slide into the housing to stop it from rotating. The nipple end should also fit into the case behind the protector plate.
Posted on Apr 07, 2017
  • 211 Answers
SOURCE: husqvarna 136 chain saw
Hi
high speed H=3/4 turn
low speed L=1 1/4 turn
iddle speed adjust accordingly
best regards savumihai71
Posted on Jan 09, 2009
  • 13 Answers
SOURCE: i cant get oil to the chain on my husqvarna 345.
You may have a problem with blockage in the oiler system somewhere. Try emptying out all of the bar oil and swishing some gas around in the bar oil tank to clean it out. This will work some of the time. Sometimes you have to take the oiler off and blow thru the lines into the tank,( make sure the oil fill cap is off) and blow into the oil tank out thru the line to clear out any debris . The adjustment for the oil pump should be on the bottom of the saw. Here is the manual with the procedure on page 32 of the manual. Hope that helps you.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140235-95.pdf
Posted on Jul 16, 2009
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
  • 4088 Answers
SOURCE: "L" adjustment screw on the carburator
L is for idle speed mixture and H is for full throttle mixture. Adjust H, when engine is warmed up, with full throttle--adjust for high speed, but 4-stroking which should smooth out just as soon as you start cutting. Allow to idle and adjust L for smooth idle, but rich enough to allow the engine to 'follow the throttle'. Set idle speed screw to just allow the chain to stop moving.
Posted on Sep 13, 2009
  • 2239 Answers
SOURCE: I have a husqvarna 435 chain saw and need to
There is a special tool required, the part no is 530035560 available from Husqvarna/Jonsered dealers, as posted earlier this should be a dealer adjustment as the machine is new.
Posted on Jan 05, 2011
Husqvarna 50 chain keeps coming off
Are you adjusting the chain tension correctly?? Make sure the bar in installed correctly with the tension adjustment pin in the appropriate hole. Elevate the tip of the guide bar while adjusting the chain adjustment screw until the chain is snug but not tight. Then tighten the bar bolts without lowering the tip of the bar. Also ensure the drive links are engaging the sprocket correctly.
If the chain is adjusted correctly and the problem still exists, remove the sprocket side cover, bar and chain and inspect the sprocket for extreme wear. Once the sprocket is worn excessively it won't want to engage the drive links of the chain correctly which could be the source of the problem. If so, replace both the sprocket and the chain because the excess wear of the sprocket could have damaged the drive links of the chain and putting an old worn chain back on with a new sprocket will cause the new sprocket to begin wearing prematurely.
Apr 12, 2015 | Husqvarna Garden
The chain on my Husqvarna saw keeps coming loose
dear
with the passage of time it gets loose. and manufacturer always provide adjustment screw. try to find that screw and adjust it. for further assistance you are wellcomed
Oct 19, 2014 | Husqvarna Garden
Installation of new chain on 16 " chain
Make sure the chainbrake ( if if fitted ) is off by pulling the hand guard fully back to the top handle, remove the securing nuts and remove the side cover, wind the chain adjuster back if it is in the crankcase, pull the bar fully back, now loop the loose chain off the tip of the bar and over the sprocket, re fit the new chain over the sprocket, and lay it around the guide bar, place the bar adjuster hole onto the adjuster pawl ( if it is in the crankcase ) refit the side cover, if the adjuster pawl is in the side cover make sure it fits into the hole in the bar, put the securing nuts back on finger tight, adjust the chain so as it fits snuggley around the bar, with a gloved hand pull the chain around the bar to make sure it is seated correctly, re adjust if required, lift the bar nose up and fully tighten the securing nuts, after the first ten minutes of use re check the chain tention as there will be an initial stretch.
Jul 02, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I remove the chain on a Husqvarna 455 Rancher chain saw
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, remove the bar nuts ( 13mm ) if it has tooless chain adjustment flip the nut wing out and undo the big grey nut, screw the chain adjuster fully back, if tooless wind the knurled adjuster fully back, now remove the side cover/brake assembly, loop the chain off the nose of the bar, and then over the sprocket and remove.
Apr 15, 2011 | Husqvarna Garden
What are the steps to replace a chain on a Husqvarna 345 chain saw?
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, now remove the two 8mm nuts securing the side cover, screw the chain adjuster in the crankcase fully back toward the sprocket, assemble the guide bar over the guide bar bolts and slide it fully back toward the sprocket, now loop the chain over the sprocket and lay it inthe guide bar raiuls and around the guide bar nose, make sure the sharo endge of the cutters on the top of the guide bar are facing away from the machine ( as you loog at it, it rotates clockwise ) now align the hole in the guide bar with the adjuster pawl, re assemble the chainbrake side cover back onto the saw, and fit the bar nuts finger tight, adjust the chain adjuster so as the chain is a snug fit all the way around the guide bar, with a gloved hand pull the chain around the bar manually, so as to make sure it is completly seated in the sprocket and bar rails, re tension if needed, hold the tip if the guide bar up and fully tighten the bar nuts.
Job done.
Jan 23, 2011 | Husqvarna Garden
How do you adjust the chain tension on a husqvarna 350 chainsaw ?
I don't own a 360, but most saws you have to loosen the two nuts that hold the bar on, and adjust the adjusting screw that points toward the front of the saw while holding up on the tip of the bar. Tighten until the chain is snug, but still loose enough to be able to spin the chain on the bar.
Dec 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 350, the chain continues to free spin after trigger is released.
Is the chain loose?
ee42fee.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Oct 29, 2009 | Husqvarna Chain Saw 20" Bar
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
81 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
