Question about The Office Equipment & Supplies
The front rollers on my Ultima 65 laminator are not turning. I have removed the panels and can see that the chain is moving along, but it is not turning the roller.
  • The Master
  • 16,806 Answers
IF the chain is moving then you need to check the shafts that the gears connect to and if they are moving then the roller pads have come loose from the shaft and need replaced.
Posted on Dec 02, 2016
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Top roller of GBC ultima 65 not heating
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
westco laminating services....405-324-6092
Oct 23, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Laminator won't heat up
This is just rediculous. Where's the friggin answer?
Mine won't even come on. JUNK!
Jan 28, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Gbc ultima 65 won't heat up.
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
Oct 02, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Laminator squeals
The paper is fed into the laminator by rollers usually a top and bottom, one of them is usually made of silicone(rubber) check to see if tose rollers are turning, you may have to pull some covers off to see the rollers, but usually you can look in the throat where the paper is fed in and see these rollers with a flashlite. Not sure of the brand, big or small laminator, good luck. If rollers are not turning, some are belt driven, some are motor driven, could even be a control board or switch.
Sep 24, 2013 | ACCO HeatSeal Ultima 65 Roll Laminator...
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
My ultima 65 laminator is not sealing well on the left side. I've tried adjusting the upper tension which helps temporarily, but it reloosens after just a few minutes of use.
By "upper tension" do you mean the hex screw located inside the left panel? If you tighten this until there is no space between the heat rollers it should eleminate the problem. If it is continues to loosen, back the screw out, apply a small amount of locktight to the threads before replacing the screw.You can find locktight at any hardware store usually in the Paint section near the glues. Hope this helps. Good luck
Feb 16, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
