Question about Craftsman Garden
Craftsman Leaf Blower will only rev up about 1/2 power at full throttle. Any suggestions?
I have installed a new Carburetor, spark plug and fuel tank with new fuel filter. I check the screen in the exhaust and it's clear, air filter is clean too. I put in fresh gas and still only half power at full throttle. It starts easy now, 2 pulls, just lacking power.
  • Craftsman Master
  • 16,231 Answers
If this is a two cycle engine there are adjustment screws that set the fuel mixture when the throttle is depressed.
Posted on Dec 02, 2016
Echo ES210 Blower will not start
Since you are getting spark from the plug it sounds like a fuel problem. I would check all the fuel lines and make sure they aren't plugged and ensure the filters are clear.
Jun 27, 2016 | Echo Garden
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
My fl1500le blower starts in full choke but dies as soon as i move it to half choke
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the fuel tank
  • Spark Plug
  • Spark Arrestor - at Muffler
  • Carburetor - May need a rebuild kit
Also watch this...
and this one as well...
Dec 10, 2013 | Weedeater 2 Speed Gas Blower FL1500LE ()
Leaf blower runs on half choke
My craftsman leaf blower ran great for 4 years.. It stop running on me one day while using it.. I replace the carb, muffler and fuel filter with a new one.. it still will only run when the choke is half closed and don't run good doing that.. I have also noticed oil around the plug and muffler. I have to use either to get it started and I noticed when I pour a little oil in the spark plug hole before cranking it seems to run loner but not at full throttle think it might be piston rings shot.
Nov 11, 2013 | Craftsman 25cc Gas Blower
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Craftsman gas blower no start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
CRAFTMAN LEAF BLOWER WONT START
1) spark plug
Chain Saws:
Remove Carburetor
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
After getting hot the blower will blow very hard at full throttle and then loose power and then back to full throttle after 2-3 seconds. It does not do this when it first starts off cold. I have relaced...
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 15, 2009 | Echo Inc. 25.4 CC Backpack Blower
My craftsman leaf blower will not start.
Basics to check:
- aluminum or silver - piston/cylinder scored
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
This Model 358-797251 Leaf Blower will not start. What can I do to make the engine run at the regular speed?
Basics to check:
b) is there spark
1) spark plug
Remove Carburetor
Oct 19, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
