Question about Element Electronics Televison & Video
How to adjust the screen size on model FLX3211b its too big for the screen
How to make big screen on nokia phone go back to small screen
Nokia phone? Please post model no. Usually there are two options there is the pinch to zoom , so place two fingers diagonally opposite each other and bring to the middle but this does not alter the big screen program in nokia phones , depending on the model you can hold the main menu button and close Big screen app , should return to normal size , more detail appreciated
Jul 07, 2014 | Apple iPhone Smartphone
How to adjust screen size on a sylvania tv
ther 2 way you should be able to do it with some model picture size or zoom but there some if you got converter box sometime you will got in the bottom of the remote a button it wil do the same joob(atlantic box got this advance knob
Mar 25, 2014 | Televison & Video
Philips magnavox 6P6030 W101 picture is too big and can't see the outer edge of the full picture
Not easy with a older set----look to see if a physical control exists in the set for Vertical size (picture too tall) and the adjustment may only exist in a hidden on screen menu.
Jun 11, 2012 | Televison & Video
I have a viewsonic GA655 monitor and the screen is too big so you cant see part of it. How do I make it fit in the monitor screen? How do I adjust the size and geometry?
You didn't specify which operating system you're using! If using Windows 7 go to start --> control panel --> and under the category "Appearance and Personalization" choose "Adjust Screen Resolution", and adjust to an appropriate size!
May 05, 2011 | ViewSonic GA655 Monitor
The picture is too big for the screen. The four buttons will only adjust colour and contrast - not size
To adjust the screen size (resolution) you have to right click on an empty place on Desktop, select Properties and then Settings. Under screen resolution change it to more, until it shows under it 1024x768, or even bigger if you want and it is possible.
Dec 22, 2010 | Packard Bell 15".28 1024x768 Beige CRT -...
Screen to big !!! icons extra big and internet screen incompletes
Hi Jessica, on your "Desktop screen," [right / alt click] to open the shortcut menu, next select one of the choices for the "icon size, ie: Medium or Large. In the same "Desktop" shortcut menu click on "Personalize," in the next window, left "Tasks" area, select and open the "Adjust font size (DPI), change the size in the [DPI Scaling] window, select the "Default scale size (96 DPI)," or you can use the {Custom DPI...} below to change the size, to your preferences. If the suggestions helped, show your appreciation for the services by giving a "Helpful Rating" thank you for using "Fix' Ya."
Aug 07, 2010 | Computers & Internet
Picture too big for screen.
go to menu and adjust screen size(picture size)
Jul 29, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
you need to go into the picture menu, and play around with the screen size options.
Jul 12, 2008 | Televison & Video
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
