Question about Ovens
Baking-burned bottoms-even baking-hotspots? - Ovens
    Top Expert:
  • Ovens Master
  • 41,454 Answers
All cooking shows suggest rotating the item being baked midway through the total time .
Posted on Dec 02, 2016
What would cause the broiler element to override the baking element? My oven has lost its mind. It doesn't matter what setting I use, The broil element takes over and burns everything. Please help.
Not 100% sure but my guess. Most electric ovens usually bake with both elements on. The bake element(bottom) is usually on at full power with 240 volts to it. The broil element(top) is usually on at 1/2 power 120 volts to help even out the temperature. My guess is your bottom element is not coming on at all either because it is burned out or something in the control system. So what is happening is the oven is trying to heat to the set temp with only the top element keeping it on much longer than it normally should be on and burning everything. Now if you set the oven for bake and the top is on red hot, you have a control system problem something like a bad selector switch or main control board if the oven has a electronic control.
Apr 10, 2015 | Ovens
My baking element burned into. can my oven work with just the broil element or does it need both.
I don't know if the broil element will work with the thermostat -- it's usually run full on. You could experiment and see, but the oven will not work correctly with just that element. You're used to baking with heat from the bottom and there is a difference. You might get away with it for pizza and meats -- MAYBE. But, even if it does work with the thermostat, do not try to bake with it unless you plan ahead to throw whatever you're baking away. Cakes, pies, etc. will be ruined with hea from the top. Replace the element -- they're not too expensive and they're easy to change. Just turn the power off first!
Dec 03, 2009 | Frigidaire GLEB30T8A Electric Double Oven
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Kenmore oven lower element sporadically heating.
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
Concealed oven
consealed bake means that the bake element on the bottom had a metal plate above it to make it easier to clean and to allow you to use the lower racks without burning the bottom of your food. To use, you want to make sure that the oven temperature that you set has been reached before putting in your food to be cooked. You also should put the racks one notch lower than you normally would. If you do this, you should have no problems with your food cooking unevenly.
Jun 28, 2007 | Amana AOCS3040SS Electric Single Oven
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
