Question about Westinghouse Washing Machines
Model LT809 S Westinghouse error message PU won't spin water out just bibs
  • 822 Answers
Pump blocked.....
Posted on Dec 02, 2016
Testimonial: "Great now i can tell the repair man what the problem is"
Westinghouse LT809 S Won't spin water out message PU
Won spin water out message PU Google Search ..try this did not put make or model if you dont find what you are looking for her just put in your make and model into google and see if it finds something to do with your model.
Dec 02, 2016 | Washing Machines
Electrolux EWT806 - PU Error Code
Pu is short for pump. You say you checked the motor and filter, but is the motor actually running when it should? If it is, you can hear it. If not, there may be a problem where the pump is not receiving power. Armchair troubleshooting isn't the same as actually being there. Keep hunting and you will find the cause.
Jan 11, 2015 | Electrolux Washing Machines
Won't spin and water is left and error message 3d
Please check the program controller unit and also the drain pump which could be clogged.
Check this link for tips and advice :
Jun 25, 2012 | LG WM2688HWM TROMM SteamWasher
Turn the boiler off. Connect a garden hose to the drain bib. Shut the water supply valve off.
Open the drain bib and drain boiler. Close drain bib and open supply valve.
When boiler is full, go to the farthest faucet and open the hot water and let run.
Go back to supply valve and turn off and on a couple of times rapidly this will "bounce" sediment loose.
Repeat above twice.
Nov 08, 2010 | Heating & Cooling
My simpson eziset605 came up with an error pu now it doesnt spin... i turned machine off and left it over night... tried again it washed ok but doesnt spin... the water drains out but the clothes are still...
PU is pump the drain pump probally has a hair clip or stone or summat interfearing with the **** impeller. if the pump doesnt function correct then it will not go into spin mode.
May 21, 2010 | Washing Machines
Clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
Apr 23, 2010 | Clarion Car Audio & Video
I have a Westinghouse mastermind 708 washing machine and it does not spin after wash cycl. i think it might be the pump to pump water out, it still makes a humming noise
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Oct 23, 2009 | Westinghouse Washing Machines
Leaking outdoor hose bib
ok this is an easy one.  you have what is called a  frost free hose bib.  this is split or has a hole in it after the seat.  the seat is inside the house wall.  you need to cut off the copper inside the house and replace the valve .  if it is not a solder joint than have someone hold back on the copper on the inside and you should be able to spin it off and replace it.  P.S if this is the case make sure you use T-tape on the threaded conection
Jun 21, 2009 | Plumbing
Washing Machines Logo
41 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
