Question about Refrigerators
Dryer purchased March 2016 and it shuts itself off on every cycle except Timed cycle. Serial # oE645AUG700093K
Model number DV48J7770EW
  • 38 Answers
Sounds like the sensors are detecting dry and shutting off. The vent could be clogged or crushed. Possible dryer vent is to long before it gets outside. Back pressure air causes sensor to shut down.
Posted on Dec 02, 2016
Whirlpool wed4815ew1. Timed Dry works, timer advances. Automatic Dry does not. Plenty of heat, clothes dry fine. Bought new timer W10185982 STILL doesn't advance
Hello David. We regret to hear about your Dryer not working on select cycles. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If that does not help then we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 08, 2017 | Whirlpool Dryers
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
I have a Iver Johnson 12ga double barrel with 30" barrel's s/n 28586 How old is it and What is the Value?
These will all help you.
Iver Johnson's Arms & Cycle Works - American Firearms
www.american-firearms.com/.../Iver%20Johnson's%20Arms%20.../Iver%20Johnson's...
  1. Cached
  2. Similar
Aug 7, 2011 - Single top latch, 100'000 were manufactured in 1894, serial number without letter prefix, marked on the top of the barrel rib. IVER JOHNSON'S ...
*IVER JOHNSON SERIAL NUMBERS ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Jan 11, 2012 - 15 posts - ‎10 authors Is the gun large frame or small frame, hammerless or a hammer gun? ... I have a Iver Johnson Top Break 5 shot hammer gun. ... I just purchases an iver Johnson hammerless 5 shot top break revolver. Iver Johnson Serial Numbers 6 posts 26 Jun 2016 Iver Johnson Serial number help 15 posts 1 Nov 2014 Old Iver Johnson shotgun 12 posts 10 Nov 2011 Need Info on Iver Johnson Hammerless Revolver 15 posts 13 Apr 2006 More results from www.thefirearmsforum.com
Blue Book of Gun Values - IVER JOHNSON ARMS & CYCLE WORKS
bluebookofgunvalues.com > Gun Values
  1. Cached
  2. Similar
IVER JOHNSON ARMS & CYCLE WORKS gun model and pricing information.
Iver Johnson Arms - M1CarbinesInc.com
www.m1carbinesinc.com/carbine_ij.html
  1. Cached
  2. Similar
Introduction to Iver Johnson, Iver Johnson's Arms, & Iver Johnson's Arms & Cycle .... With the exception of the D-Day Carbines the serial number on Iver Johnson ...
manufacture date of Iver Johnson revolvers based on serial number ...
www.rimfirecentral.com > Other Rimfire Guns > Misc -- Other Rimfire Rifle Brands
  1. Cached
May 17, 2016 - 14 posts - ‎3 authors There is a serial number listing for the Iver Johnson SuperShot 22 Top Break Revolvers in W.E.Goforth's book/reference, "Iver Johnson Arms ...
Iver Johnson - Wikipedia
https://en.wikipedia.org/wiki/Iver_Johnson
  1. Cached
  2. Similar
Iver Johnson was a U.S. firearms, bicycle, and motorcycle manufacturer from 1871 to 1993. .... William McKinley in Buffalo, New York on September 6, 1901 with an Iver Johnson .32 caliber Safety Automatic revolver (serial number 463344). Iver Johnson 12ga Google Search
Nov 30, 2016 | The Optics
Electric dryer..have heat on auto heat cycle, but no heat on timed cycle why?
If you have normal heat on Auto cycle, I have seen a few times that these new dryers channel the heat circuit separately through the timer for auto and timed cycle's. This isn't normal but you have a bad timer. But for any other readers this isn't a common problem generally the timer use's the same heat contact for auto and timed cycles, this is the exception.
Mar 26, 2015 | Whirlpool Dryer. 3.8 cu. ft. Electric...
KitchenAid electric dryer, Model # 750LQ, has a broken (I believe)cycle selector (timer) control. The dryer turns on when the control is activcated by turning to the right, but is not in automated mode...
If you are setting the unit on automatic and the timer itself is not moving forward to the shut off position and you have to manually turn the timer off then you would need to order and replace the timer itself. If you have any further questions message me back Thanks Rick
p.s If you need me to look up the part number for your unit please provide the full model number of your dryer and I will try to locate the part number Thanks Rick
Jul 01, 2011 | Dryers
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
Gas kenmore dryer
It could be a couple of things, but I would start with the flame sensor. Different models work differently.
Jan 03, 2010 | Kenmore 74962 Gas Dryer
My dryer will automaticall start the auto dry
appears that timer is not timing out or shutting off at end of cycle.correct ,the timer itself appears to be the problem.
Oct 16, 2009 | Dryers
Estate dryer will not get hot in any cycle, also will not turn off by itself
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model is always helpful when requesting information.
Unplug dryer before testing.
For your symptom the problem usually is the heater coil burned out. Inside rear cover in a can on the right side. A burned out coil will prevent heating and in the automatic cycle the timer will not advance if the heater is out. You can verify this by using the timed cycle. In timed dry the dryer should turn off even without heat.
Aug 22, 2009 | Estate Dryers
Dryer won't shut off after cycle
i got to know what cycle you are using the timed dry or the auto cycle timed dry you may have a bad timer if auto dry it coult be the auto dry resistor or it could be a clogged vent.
Jan 19, 2009 | Maytag PYG2300A Gas Dryer
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
