Question about Panasonic Televison & Video
Sanyo 42" TV Model #DP42740 Panasonic #EDO2402637 trouble shooting.
Have replace the Power Supply board from ShopJimmy (Part #N0AB6J00001) and still have same problem (will not turn on, only click on and then off for about 20 seconds, no picture or sound. Will do this for as long as I try which I have tried over 6 times. What should I do next?
  • 822 Answers
A/v board.........
cheers
Posted on Dec 04, 2016
  • 1894 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
was that capacitor damaged?
Posted on Jan 11, 2008
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: power light comes on and clicking is heard but no
your problem is more a defective y board with y buffer boards one of them is short
Posted on Oct 26, 2010
  • 8457 Answers
SOURCE: I'm working on a sanyo 50" hdtv, It wont power on,
The power supply board have 6 capacitors dead,must have very high current going through the tv to have that many cap to died on the power supply board.U have good electronic skills trouble shoot the power supply board again,have something else is dead in there?Or try website like Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Nov 24, 2010
eagle338
  • 4889 Answers
SOURCE: I have a Sanyo DLP
Sanyo plasmas have LEDs on the boards that can be used to identify the source of the problem. Are LEDs on any of the boards lit> If yes then which ones?
Posted on Apr 06, 2011
Where is located the fuse in a tv sanyo model No. DP42740
There are several fuses on the power supply board.
The main one is right next to where the cable from the AC connector is on the power supply.
BTW you may want to check these listings too:
http://www.coppelltvrepair.com/search?q=DP42740
(although if you are looking for a fuse that probably means totally dead TV and if that;s the case then you do not need a main board repair)
Apr 14, 2014 | Sanyo DP42746 42 in. Plasma Television
Tv come on no pictuee and goes off after 30 sec. it keep on doing this unless I unplug it.
The tv power supply board that the board where the power a/c cord plug into it.The tv power supply board it is dying and the causes,it is not holding and sustanstance tv power voltages anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 25, 2011 | Sanyo 42 in. LCD TV
My tv keeps turning itself on and off
Power supply boad have problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 17, 2010 | Sanyo 42 in. LCD TV
Have a Model No: DP42746 TV will not turn on nothing lighting up have electric at outlet owned for about 3 years
Tries unplug,replug tv it back about hour later.The tv will reset itself back to factory.See if it work than.Not the power supply board,it dead.That the board,where the power a/c cord plug in to it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 21, 2010 | Sanyo DP42746 42 in. Plasma Television
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2010 | Sanyo 42 in. LCD TV
My 42in panasonic plasma viera blinks 10 times and will not turn on
Apr 02, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Mar 26, 2010 | Sanyo 42 in. LCD TV
Sanyo 42 inch plasma not turning on, not power showing
Power supply board it dead,must replaced the power board.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 06, 2010 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
