Westinghouse LT809 S Won't spin water out message PU
    Top Expert:
  • Washing Mach... Master
  • 8,376 Answers
Won spin water out message PU Google Search ..try this link..you did not put make or model if you dont find what you are looking for her just put in your make and model into google and see if it finds something to do with your model.
Posted on Dec 02, 2016
Won't spin and water is left and error message 3d
Please check the program controller unit and also the drain pump which could be clogged.
Check this link for tips and advice : www.espares.com
Jun 25, 2012 | LG WM2688HWM TROMM SteamWasher
My Westinghouse LT 9555 washing machine won't spin how to fix problem??????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 06, 2010 | Westinghouse Washing Machines
Our simpson washing machine is not spoinning and the letters PU flash on the electronic display panel.
PU is pump fault. Usually caused by a blockage. Machine will not spin until all water is drained
Thank You
Sep 09, 2010 | Washing Machines
My simpson eziset605 came up with an error pu now it doesnt spin... i turned machine off and left it over night... tried again it washed ok but doesnt spin... the water drains out but the clothes are still...
PU is pump the drain pump probally has a hair clip or stone or summat interfearing with the **** impeller. if the pump doesnt function correct then it will not go into spin mode.
May 21, 2010 | Washing Machines
I have a Westinghouse mastermind 708 washing machine and it does not spin after wash cycl. i think it might be the pump to pump water out, it still makes a humming noise
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Oct 23, 2009 | Westinghouse Washing Machines
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
