What is needed to fix colors images all run together in Sony KDL60R510A
  • Televison & ... Master
  • 17,322 Answers
Optimal hdtv settings for sony KDL60R510A
Picture setting will depend on your viewing interest. It will differ person to person. Gopakumar Gopalan Google
Mar 01, 2015 | Sony Televison & Video
I have a large blue spot in the center of my screen. How can I fix this?
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Found yours here http://www.discount-merchant.com/SONY-1-788-155-21-p/1179590.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I HAVE A SONY KP-53V90 53 INCH REAR PROJECTION TV AND THE COLORES ARE NOT MERGING TOGETHER PROPERLY I THINK THIS IS CALLED A GHOST IMAGE HOW CAN I FIX THIS
You have a convergence issue, will have to check convergence IC,S or just replace them there are usually two of them mounted on heat sinks they are usually STK'S with a number after. Also must check fuseable resistors supplying +15 and - 15 volt s to the chips. After replacement some convergence alignment may be needed. Good Luck.
Mike
Apr 15, 2010 | Sony KP-53V90 53" Rear Projection...
Uneven color and brightness on modelkds55a2000
Hi, it sounds like a problem with your light engine.This is a very common failure on Sony sets.Let me explain how your tv works.The uses a lamp that the light of the lamp is directed by mirrors to 3 LCd chips that are like tiny screens that create the colors and image by blending together.If there's any color discoloration its because of those chips.In order to fix this problem you will need to replace the light engine. On this website you might be able to find it www.discount-merchant.com?Click=48173 the brightness might be afftected by the lamp that is going bad.Your Philips lamp last 6000-8000 hrs 2-4 yrs.First replace the light engine or contact sony.Good luck and God bless you!
Nov 06, 2009 | Sony KDS55A2000 55" HDTV
I have pink streaks in the screen, can't see them when pix is in color, only light or no pix
Hi,Sony is well known for having issue with their light engine.Basically what creates the image and colors on the tv is 3 LCD chips which are blue,green and red.This chips blend together to create the colors and image.When they start to go bad you will get that color discoloration.You will need to replace the light engine. You can find it here http://www.discount-merchant.com/SearchResults.asp?Search=1-788-155-21?Click=48173 or shopjimmy.com God bless you!
Nov 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
The colors are not coming together. I can see red
You have bad convergence amplifier ICs. May also have associated low value resistors and or pico fuses open.
Oct 16, 2009 | Sony KP-57WS500 57" Rear Projection...
Kp-46wt500 shadow and slanted images with rainbow colors
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
