Question about Lucent Lands Phones
My incoming calls on the Lucent 18 rings once and then goes to voice mail. How can I fix this?
dr reed
  • 379 Answers
SOURCE: All of my incoming calls go directly to voice mail!!
try turnin ur voice mail off and discornecting it so that voice mail wont be abel 2 be acsessed
Posted on Feb 18, 2008
  • 111 Answers
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
Posted on Oct 28, 2008
  • 4 Answers
SOURCE: Interel voice mail rings
In System Timers change the System Forward Initiate timer. Be cautious that this is a system wide timer and will affect all users. If you want it done just on one phone it gets a little bit more complicated but it is still possible.
Posted on Dec 31, 2008
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
should see the normal display then.
Posted on Jan 16, 2009
  • 5 Answers
SOURCE: LG Rumor2 Phone will not ring. It goes to voice t...
menu- tools- voice control-voice guide- alert off
Posted on Jul 24, 2010
My phone rings once and shows "Incoming call" on the LCD screen and when I answer, no one is there. People calling say the phone only rings once or it goes directly to voice mail.
You have to go into the menu and reset the rings so that the phone will ring at least 4 times. Your owners manual should give you directions to do that. You can also call Panasonic.
Aug 29, 2011 | Panasonic KX TG4023 Cordless Phone
All incoming calls go direct to voice mail,phone does not ring.
You may have turned the radio off on your phone by activating Airplane mode. This mode will send all calls to your voice mail.
Check your owners manual to re-active your phone to Normal mode.
Apr 07, 2010 | Nokia 6700 Classic Cell Phone
Phone rings only once then is silent. How do we
This is a symptom of a feature that has been activated. It could be the call is forwarded, it could be the voice mail is programmed to pick up on the 1st ring. On some systems ext's can be programmed to ring elsewhere after a set number of rings. The do not disturbe feature could be activated. If it is an outside line, call it from your cell and see what you get (voice mail-continious ring-another ext etc.) Find out if it does it on an in houes intercom call. Look for a DND button the it lit up? Does the display show calls forwarded or DND? Hope this helps. Good luck.
Mar 24, 2010 | Lucent Merlin Legend MLX-20L Phone
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Phone keep ringing when incoming call is not picked up (and reach voice mail), and then hang
I need to know more details,
Can you tell me whether you have lotsa messages in your phone?
Jun 28, 2008 | Nokia 1600 Cellular Phone
Changing number od rings
Are you talking when calls come in on the main number or calls going to an extension?
Jun 27, 2008 | Lucent PARTNER18 Corded Phone
Voice mail garbled
I have run into this problem in the past. Power off the telephone system. Power switch is on the top (back) right of the cabinet or you can unplug it from the wall. Be carefull , if your memory battery is bad, you will lose programming on the phones.
cycling power to the system has fixed this in the past for me, if this doesnt work you may have to replace the vm card in the system.
Mar 12, 2008 | Lucent PARTNER18 Corded Phone
This can be very complicated! You may need to get a local installation company to come in and help you out. It sounds like the memory battery in your system is bad and needs to be replaced or this will just keep happening to you.
Your phone can be used on one of several different Avaya phone systems and you can have different voice mail systems also. You need to figure out which phone system and voice mail you have. All the manuals are available at but if you have never dealt with programming this system before it will be a big task to learn it.
Nov 06, 2007 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
